Post new topic Reply to topic  [ 6 posts ]
PostPosted: Fri Aug 17, 2012 1:32 am
I installed some Extralite pulleys on my Sram Force derailleur the other day but ran in some troubles.
When i crank down the pulley bolts, the pulleys don't spin smooth anymore and get pinched, which causes drag.
But when i loosen the pulley bolts, the outer cage can 'move' in the slots for the countersunk pulley bolts. The outer cages doesn't fit tight.
Anyone had this before or knows a solution?
I Will make the leap
PostPosted: Sat Aug 18, 2012 11:18 am
Nobody? :(
PostPosted: Sat Aug 18, 2012 11:54 am
Extralite lists their pulleys as Shimano and Campy compatible but no Sram.
Does your Sram Force have some different sized pulley bolts?
In that way that the upper pulley original bolt is a M4 bolt and the bottom one is a M5?
If yes you should have a slight play in your upper pulley but having described problems with both pulleys is a very special case.
PostPosted: Sat Aug 18, 2012 1:45 pm
I use a sleeve for the M4 pulley
PostPosted: Sun Aug 19, 2012 4:06 am
Hard to tell without seeing them in person. The 2 discs that sandwich the bearing shouldn't bind it if they're the correct diameter. If the bearings are the same diameter as the original one's, you could try the Sram discs to see they bind also.
PostPosted: Sun Aug 19, 2012 10:21 am
I solved the problem.
The conical head of the pulley worked a little bit as a wedge and pushed against the bearings.
With the demel i made the diameter or the sleeve a little bit bigger on the outside, so that it matches the conical head of the bolt.
Users browsing this forum: Bing [Bot], Blank81, go4custom and 46 guests
There are no new unread posts for this topic. I'll give a thumbs up to FSA customer service
rainbowstripes
Thu Jul 26, 2012 3:19 am
rainbowstripes View the latest post
There are no new unread posts for this topic. Attachment(s) AFC Pulley Wheel Review.
weeracerweenie
43
2220
Wed Nov 28, 2012 10:45 pm
weeracerweenie View the latest post
There are no new unread posts for this topic. recommend a rear pulley please
Bianchi10
Sun Sep 23, 2012 11:25 am
sugarkane View the latest post
There are no new unread posts for this topic. Why my 2013 Sram red rear der throws the chain off pulley?
glowder
14
1250
Tue Dec 04, 2012 5:01 am
spud View the latest post
There are no new unread posts for this topic. Speedplay Zeros problems
SSB
23
1279
Tue Sep 04, 2012 7:08 pm
fitty4 View the latest post
It is currently Tue May 21, 2013 4:20 am
