It is currently Mon Jan 22, 2018 7:20 pm
Post new topic  Reply to topic  [ 12 posts ]
PostPosted: Thu Aug 16, 2012 9:10 pm
Anynother users out there find this comes loose? I have now tried a Tune Gum Gum with success but does the steerer need the support of the dale top cap?
PostPosted: Thu Aug 16, 2012 9:51 pm
I found the same thing so I pulled it out and put carbon paste around expander before tightening again.
Second question, I prefer the added support the top cap provides. I tried a Extralite expander and could see the steerer deformed when stem was torqued.
PostPosted: Sat Aug 18, 2012 8:34 am
Are you now using the standard top cap again. I was thinking of getting an ultrastar for my evo build.
PostPosted: Sat Aug 18, 2012 10:11 am
Have installed the standard cap again with carbo grip, but if it slips at all will go back to gum gum. This does reinforce the steerer too.
PostPosted: Sat Aug 18, 2012 2:58 pm
Thanks for your heads up, I just bought a Evo and will keep an eye on the topcap. Interesting idea, so you do not need to remove the preload when tweaking the stem as I dial in the fit.
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
PostPosted: Sat Sep 15, 2012 8:02 pm
Back to gum gum but this does need a lot of tightening to get the right preload on the headset
PostPosted: Sat Sep 15, 2012 8:07 pm
You do not add preload with a gum gum, you first set preload with a real expander such as the stock one then remove and install your gum gum/tune cap ect.
Curt Brown
2016 Cannondale EVO Etap 13.8#'s
2012 Cannondale Supersix EVO etap 13.7#'s
2017 Cannondale SUPER X Force 16.0#'s
2016 Cannondale FatCad2 28.1#'s
2011 Cannondale Carbon Flash 1 17.9#'s
PostPosted: Sun Sep 16, 2012 2:03 pm
ok i see
PostPosted: Sun Sep 16, 2012 9:09 pm
If you do this, wha is the point of the gum gum?
PostPosted: Mon Sep 17, 2012 12:07 am
Just to have the top cap something to screw onto. And oh, weight savings :)
As for me, after everything's torqued down properly, I remove the expander plug and just put a small amount of super glue on the top cap and screw. :thumbup:
PostPosted: Mon Sep 17, 2012 12:17 am
Typical savings are 35-50 grams, lots of grams for the buck, even go cheap with an omni racer carbon cap/expander at $15 and 15 grams, did that one on my Super X and the tune/gum gum on the Evo(14 grams).
Curt Brown
PostPosted: Mon Sep 17, 2012 1:10 pm
gumgum worked just fine on my first ride with it on my evo. it was a very small ride, like 5 miles, but I intentionally hit as many potholes as I could just to try it. all handed fine so far. on a less note, my mechanic did all for me, as Im still learning my way into assembling all parts.
There are no new unread posts for this topic. Guide me to the best open mould frame (super light and super stiff)
KOMwannabe
Tue Nov 21, 2017 2:11 pm
KOMwannabe View the latest post
There are no new unread posts for this topic. Steerer offcut weight
SABARRAS
Thu Feb 02, 2017 12:29 am
SABARRAS View the latest post
There are no new unread posts for this topic. 0 Degree 1.25" Steerer Stems?
HugoDrax
Sun May 07, 2017 9:09 pm
HugoDrax View the latest post
There are no new unread posts for this topic. Lightest Stem with 40mm Steerer Clamp
Lelandjt
9
608
Thu Dec 07, 2017 8:44 pm
stormur View the latest post
There are no new unread posts for this topic. Attachment(s) Canyon aeroad steerer plug adjustment
dannyBBo
Mon Aug 07, 2017 2:21 pm
alcatraz View the latest post
Users browsing this forum: BdaGhisallo, Bordcla, bremerradkurier, hlvd, IrrelevantD, jch3n, nobuseri, TLN and 44 guests
