Post new topic Reply to topic  [ 7 posts ]
PostPosted: Thu Aug 16, 2012 3:22 am
I am thinking about purchasing a litespeed L1R and building it up with the new sram red and was wondering if i should just go with the fsa k force light evo bb386 specific crankset or if i could run a sram red exogram bb30 crank with a sram pf30 bb.
will there be any compatibility issues there, from what ive read/found so far i think it should work..
also, do you guys think one of these cranks is better than the other? and anyone else have any experience with the litespeed L1R?
any help would be greatly appreciated, thanks. trevor.
PostPosted: Thu Aug 16, 2012 4:06 am
if the frame is bb30, you should get a bb30 crank. if youre getting a NewRed group, you ought to stick to the NewRed crank in bb30. if you really want to go with an fsa crank, ideally it would be the k-force light bb30 version instead of the bb386evo version. it's a bit lighter, nothing extra, gives you more heel/ankle clearance if you need that type of thing.
if the frame is NOT bb30, well, that rules out all dedicated (pure) bb30 options.
PostPosted: Thu Aug 16, 2012 4:28 am
My understanding is that BB30 does not fit in BB386. You need to go GXP if you want SRAM Red.
PostPosted: Thu Aug 16, 2012 5:24 am
I googled this in a few minutes.
Having said that..I don't quite understand it! :lol:
The issue is width..and whether or not your BB30 cranks will clear the frame containing the BB386 bottom bracket.
BB30 is designed for a 68mm wide bottom bracket, BB386 is designed for a 86mm wide bottom bracket.
I would guess that your BB30 cranks (which is designed to be very narrow in order for good 'Q'-factor ankle clearance) will not clear the BB386 bottom bracket.
PostPosted: Thu Aug 16, 2012 5:51 am
Read this http://www.slowtwitch.com/Tech/Bottom_B ... _2573.html
You can run BB30 on that frame or GXP they make a specific BB386 to GXP adapters... That write up explains everything about BB30 BB386 OSBB BSA BBRIGHT Etc... super informative
PostPosted: Fri Aug 17, 2012 4:10 am
I'm not sure why this is so challenging. A frame designed to the BB386 is 86.5 mm wide and takes a 30mm spindle. It will not take a BB30 crankset, which is designed for a 68mm wide BB shell. If this frame is a BB386 frame, it will take BB386 and standard 24mm spindled cranks with an adapter. That is it.
PostPosted: Sat Aug 18, 2012 3:54 am
a quick google search says your frame has a 386evo bb shell. so no "pure" bb30 cranks. if you go sram red, it has to be the gxp one with an adapter. if you go fsa, get one that is 386evo and just plug it in.
Users browsing this forum: Bing [Bot], Exabot [Bot], HammerTime2, sedluk and 60 guests
There are no new unread posts for this topic. Compatibility Issue Madone 5.2 - Selle SMP
DividedVolta
Mon Feb 04, 2013 9:53 pm
DividedVolta View the latest post
There are no new unread posts for this topic. Compatibility issue in 9070 group
sycfisher
Sun Apr 28, 2013 2:45 am
mlchang View the latest post
There are no new unread posts for this topic. Gore ride on ultralight compatibility issue
Boralb
Fri Aug 10, 2012 11:36 pm
Boralb View the latest post
There are no new unread posts for this topic. BB386 BH ultralight, what crankset will fit?
Fred72
Fri Feb 08, 2013 5:49 pm
Fred72 View the latest post
There are no new unread posts for this topic. Hollowgram on BB386 frame
Ainsy
Mon Jun 11, 2012 5:58 pm
ms6073 View the latest post
It is currently Sat May 18, 2013 3:25 pm
