Post new topic Reply to topic  [ 10 posts ]
 Post subject: DIY Disc Wheel
PostPosted: Sun Aug 12, 2012 7:43 pm
Yes, this is a half-baked idea but the engineer/tinkerer in me is looking for a new project.
Take a peek at this video:
http://www.youtube.com/watch?v=SAAEze4nMyE&feature=related
So if you were going down this path, what wheel components would you use?
I'm thinking of using a nervation m28 wheel as a 'test subject' to see how it turns out. Presuming the results are positive, I am thinking that I'd make a second wheel with a tubular rim. I am leaning towards a 32H 23mm wide rim. I'm not certain of which hub I'd use as I am thinking that a straight pull hub might help the cover seat a bit more cleanly. That being said, I don't know if straight pull are less/more apt to other issues as compared to j-bend.
-Todd
 Post subject: Re: DIY Disc Wheel
PostPosted: Sun Aug 12, 2012 8:13 pm
Ingenious! DIY Zipp! I see you also built yourself a Specialized S-Works. Build yourself some pedals next.
PostPosted: Sun Aug 12, 2012 8:45 pm
Bla bla bla.
Putting this 'Fake ZIPP' video aside this is an interesting area to explore, given that some disc wheels (HED Stinger for example) have roughly the same build concept. Given the high premiums that even the low-end disc wheels seem to have, I think there would be quite some people following this topic very closely.
Good luck and keep us posted!
PostPosted: Mon Aug 13, 2012 2:55 am
I wonder if anyone has gone down the Mavic Comete path and made a hollow disc...
Slam your stem.
prendrefeu wrote:
Hating a 'drivetrain' choice on one bike vs. another is as imbecile as people getting into fist-fights at a motor race that they are not actually racing in Australia over a debate between two car companies. It really is ridiculous.
PostPosted: Mon Aug 13, 2012 9:38 am
Interesting indeed. I wonder if you can get lower density foam, and I wonder if the foam cracks over time due to flex in the wheel.
Ultimately just using wheel covers is a lighter option
http://www.youtube.com/watch?v=8xjBCxg7 ... re=related
That said if you wanted to go the foam way - I'd use a very light low profile wide rim, like stans, and then use a lot of very lite spokes, maybe even 32 spoke Ti or spaium super spokes etc.. Not point putting weight into the rim to save on spokes, not like less spokes is going to be less aero for you. Of course low profile rims need more spoke support, but should still be nice and stiff so you can use lighter weight spokes as well.
signature deleted by the Admin.
PostPosted: Mon Aug 13, 2012 10:10 am
the video is a bit mixed up - doesn't really show what uis being done, or at least I didn't get it.
looks to me that spoke covers are made from carbon fibre to fit over a read spoked wheel, in which case, what is the point since back in the 80s or 90s it was possible to by plastic wheel covers that are lighter but with the about same aerodynamic advantage; admittedly they do not look as good.
PostPosted: Mon Aug 13, 2012 6:31 pm
Looks heavy. The rigid 3mm foam board and carbon-looking vinyl tape should be enough. Just tape it around the outer edge and then you can take it off easily too.
formerly rruff...
PostPosted: Tue Aug 14, 2012 2:54 am
If you want something cheaper, simplier and lighter just use model airplane heat shrink skin and glue it to the rim and a small diameter solid ring near the hub. J-Disc wheels back in the day were like this. Back when I was a broke student I did an old wheel this way and it worked great...still have it today. Also the airplane heat shrink skin comes in any color you want - I went with a mirror like chrome.
PostPosted: Tue Aug 14, 2012 3:11 am
Back in the day of the Tioga Disk Drive for MTB racing, guys in my town made home made versions just by using two sheets of clear thin plastic, cut to shape for each side of the wheel and connected to each side with adjoining plastic connectors. Was essentially just a clear full wheel plastic spoke cover for each side. Looked pretty cool, don't how aero it was but it I was told it felt like you went down hills pretty flicken quick with them on. :thumbup:
PostPosted: Tue Aug 14, 2012 9:38 pm
Best mate and I got bored one day and put this together. Took about 4hours of placing short sections of tape between the spokes and layering it all up. We used about 50m of duct tape on a fulcrum 3 wheelset. Was a school project. This was the first one we made. Never got around to making a second but had some good design ideas to improve on the second. Was faster than a fulcrum 3 rim over 16kms. Turned up to do a proper timed event and they didn't allow us to start. Good if your into that hipster shit I guess though.
http://www.youtube.com/watch?v=DwJh8Fte4Lw
Users browsing this forum: Google Adsense [Bot] and 32 guests
There are no new unread posts for this topic. Attachment(s) 3D Printed Disc Wheel Valve Cover with wheel Magnet
RaceWareDirect
Wed Sep 05, 2012 11:04 pm
cyclenutnz View the latest post
There are no new unread posts for this topic. Buyin a disc wheel (which one?)
tri
11
1505
Wed Jun 20, 2012 2:49 pm
Juanmoretime View the latest post
There are no new unread posts for this topic. Building my own wooden disc wheel: what hub/axle to use?
SWijland
Sat Dec 08, 2012 4:17 pm
latman View the latest post
There are no new unread posts for this topic. Aero Wheel & Disc Help Needed for TT and Road Racing
ProudDaddy
16
834
Thu Dec 20, 2012 9:25 pm
gilesharrison View the latest post
There are no new unread posts for this topic. no more disc
bikedoc
Tue Apr 02, 2013 8:13 am
euan View the latest post
It is currently Sat May 25, 2013 4:00 am
