Post new topic Reply to topic  [ 24 posts ]
Go to page 1, 2  Next
PostPosted: Sun Aug 12, 2012 11:07 am
Hi, just wondering if people think their is any real benefit of carbon tubular wheels that weigh around 1200 -1250g such as hypernon/fulcrum light/vision Trimax tc24 versus light weight clincher wheels such as the r sys sl. Purely in the context of climbing, ie sportive or climbing big cols for fun. Not for road racing or aerodynamic properties.
Given the disadvantage of tubulars such as puncturing and braking on long descents. I could understand the advantage of über lightweight wheels such as enve or ax lightness.
Any views welcome
Thanks
PostPosted: Sun Aug 12, 2012 11:09 am
The tubulars will have slightly less mass at the rim.
PostPosted: Sun Aug 12, 2012 11:19 am
Well to start with the hyperon/racing lite have better hubs. Campy loose balls are the nicest rolling hubs out there.
I'd rather ride robust steel bladed spokes over the R-SYS and its dubious CF spokes.
Nothing wrong with neutrons either.
For the $$ you are spending on these prebuilt wheels you could get a good builder to make something built for your weight and needs. ENVE rims could even be in the budget.
As far as benefits you will the ride benefits of tubs, and the light weight of tubs. Both handy for a sportive with lots of climbing
signature deleted by the Admin.
PostPosted: Sun Aug 12, 2012 7:26 pm
gb103 wrote:
Given the disadvantage of tubulars such as ... braking on long descents.
Any views welcome
Thanks
My view is your wrong on this. Tubulars brake fine. On carbon much safer than clinchers. And if you puncture on a descent, wouldn't rather be on a tubular?
PostPosted: Sun Aug 12, 2012 9:29 pm
I agree the hypernons and racing lights ceramic hub are excellent and superior to mavics.
Tubulars may break fine, but the general consensus is that clincher rims break better in the dry and wet.
My question is purely on a performance basis, ie is there now any advantage using tubular wheels that are 50 -100 grams lighter over top end clincher like the mavics. For example, a TT up Alpe D'Huez or doing a longer event such as the etape/Marmotte if bike and rider are equal.
PostPosted: Sun Aug 12, 2012 10:00 pm
Assuming you mean "brake", then no such general consensus exists - the choice of tubular or clincher makes no difference to how a rim brakes, except in the case of overheating where a clincher can blow off the rim, although a tubular can also come unglued.
If you're thinking of Tony Martin in the Worlds TT, then he chose clinchers because they offered an alloy braking surface, which is better in the wet than carbon. It's the braking surface that makes the difference, not the type of tyre.
PostPosted: Sun Aug 12, 2012 10:21 pm
Apologies I did not make myself very clear. I indeed was talking about the braking surface (carbon v aluminium). Any views on climbing performance?
Last edited by Powerful Pete on Mon Aug 13, 2012 12:07 am, edited 1 time in total.
Please do not quote immediately previous post. PP
PostPosted: Sun Aug 12, 2012 10:45 pm
Weight is weight. It's an absolute in climbing. The more of it you have, the slower you go for a given effort. The lightest wheelset you can possibly build is a low profile carbon tubular so for pure climbing, that is the best choice in theory.
That said, do a search for one of those power spreadsheets - you can work out how much difference 200g will actually make - it's TINY.
PostPosted: Sun Aug 12, 2012 11:04 pm
Thanks for actually answering the question.
I was just wondering as aluminium wheels become lighter (in clincher and tubular form) will there be any point in carbon tubular wheels that weigh around 1250g?
Last edited by Powerful Pete on Mon Aug 13, 2012 12:06 am, edited 1 time in total.
No need to quote the immediately previous post. Thanks. PP
PostPosted: Sun Aug 12, 2012 11:17 pm
There's also the Shimano DA C24 for your consideration. It has the best of both worlds (lightness and an alloy braking surface).
Carbon wheels are still improving. Aluminium rims (in my opinion) aren't likely to get much lighter or stiffer than they already are, and at the über-WW end of things stiffness and durability really tends to suffer. Unless all you do is ride uphill TTs I would still choose aluminium though, and I say this as the owner of two carbon wheelsets.
Re C24s, they aren't light enough to figure in this conversation.
PostPosted: Sun Aug 12, 2012 11:35 pm
Tubbie Guru
Hi,
This has nothing to do with tubulars versus clinchers but rather alloy rims versus carbon rims be that of the tubular or clincher conviction.
The gap is closing as we speak though.
Once again this is just not true. Tubulars should not puncture any more or less than a clincher. If anything the tubular has the theoretical advantage both on pncture resistance and sustained/repetitive braking.
In short, for what you intend to do, the tubular carries all the advantages you need. The only disadvantage I can see is the slightly inferior brute stopping power under heavy rain and then some...
Ciao, ;)
PostPosted: Mon Aug 13, 2012 9:50 am
What about the American Classic Mg wheels? Rims look good, but can't say I'm a fan of the hubs.
PostPosted: Mon Aug 13, 2012 11:30 am
In the context of climbing, the performance difference will be marginal. That is, assuming both wheelsets have similar performance. Feeling comfortable with what you ride will make a bigger difference, and you may not be as confident if you ride very light carbon wheels.
PostPosted: Mon Aug 13, 2012 12:42 pm
I had some C4 2.0 USL that I loved and have now changed to Zipp 202 (because I was switching back to Campag). To be honest the tubs are a bit smoother but apart from that I don't notice a massive difference (until I puncture). The clinchers have the added bonus that I used to use them more rather than save them for the odd special trips. Having said that I am 59 kg so pretty light on my kit.
Post new topic Reply to topic  [ 24 posts ]  Go to page 1, 2  Next
Users browsing this forum: No registered users and 54 guests
There are no new unread posts for this topic. Mavic CCU and Shimano Dura Ace C35 tubular
konky
Wed Oct 17, 2012 2:56 pm
civdic View the latest post
There are no new unread posts for this topic. mavic yksion griplink/powerlink tubular 1/2 off
ricorob
16
1987
Thu Jan 31, 2013 2:44 am
rc32 View the latest post
There are no new unread posts for this topic. Mavic exalith coating and tubular glue
gb103
Wed Dec 12, 2012 11:18 am
konky View the latest post
There are no new unread posts for this topic. Mavic helium rear wheel tubular rebuild (classic)
stella-azzurra
Sun Jul 29, 2012 11:28 pm
daj View the latest post
There are no new unread posts for this topic. 2013 Mavic R-Sys wheels?
Bianchi10
Sun Mar 17, 2013 2:32 pm
huddini View the latest post
It is currently Tue May 21, 2013 3:31 am
