Post new topic Reply to topic  [ 3 posts ]
PostPosted: Sat Aug 11, 2012 9:42 pm
Quick question. I'm struggling to set the bearing preload correctly on my Soul Prodigy V3 rear hub.
The rear axle has a screw on end cap on the drive side. If I screw this right down (until it bottoms out) then there is too much bearing preload and the axle will barely turn. If I don't screw it down fully, it works loose - I could use a bit of thread lock but that doesn't seem right!
Any advice would be appreciated. Thanks.
PostPosted: Sat Aug 11, 2012 11:59 pm
Hi Gilles,
The Prodigy hub can't be pre-loaded, as the entire assembly is spaced. What is actually going on in your hub is the washer between the freehub and hub body bearings is deformed and getting stuck on the axle. Remove the washer, flatten it with a mallet and file the inside to get it to not bind on the axle and you should be able to tighten the endcaps without any binding.
PostPosted: Sun Aug 12, 2012 6:09 pm
I did exactly what you described and it worked perfectly. The hubs now spins smoothly with the end caps fully tightened.
Many thanks.
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 59 guests
There are no new unread posts for this topic. Dura Ace 7900 hub adjustment
mikegrad
Mon Aug 13, 2012 2:00 pm
oreoboreo View the latest post
There are no new unread posts for this topic. Attachment(s) ISP saddle height adjustment
rgamble
15
1281
Wed Nov 21, 2012 3:03 pm
There are no new unread posts for this topic. Help a Newbie Out: Shimano 105 5600 RD Adjustment
Dallez
Thu Apr 04, 2013 5:01 pm
Dallez View the latest post
This topic is locked, you cannot edit posts or make further replies. Soul S2.0 wheel
addictR1
Sat Jul 21, 2012 11:21 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. BOYD/SOUL/PISMET/ROL/LIGERO WHICH IS SUPPOSED THE BEST?
RAFIUDEEN
23
2754
Thu Jul 12, 2012 7:55 pm
bluesea View the latest post
It is currently Thu May 23, 2013 1:02 pm
