Post new topic Reply to topic  [ 6 posts ]
PostPosted: Sat Aug 11, 2012 9:29 am
Wanting suggestions about crank choice for Power2Max unit to go on the racing bike (Look 586) - currently has a 53/39 SRAM S900 P2Max on it but looking to put this on the training bike. The race rig as set up at the moment is more of a climbing/special occasion bike, and am looking for a nice crank to match.
The complicating factor is I already have another SRAM s900 crank so would be very easy (and ~$600NZD cheaper) to buy a 110mm spider for it and run 52/36 stronglight rings. Been wondering about the merits of Rotor 3d (not the + model, frame suits a standard 24mm BB) or lightning, but unless the weight savings are likely to be substantial (>150g) I'm not sure it's worthwhile...
PostPosted: Sat Aug 11, 2012 9:41 am
Hi, not going to be much help on the crank choice dilemma- all I can say is that a friend of mine has the Rotors and is very happy with them.
I'd be interested to get your feedback on the P2M though- you must be happy with it if you are getting a second one?
I was considering it, but have to admit by being a bit put off my the temperature linked zero offset drift, which cannot correct unless you freewheel.
What has been your experience of this?
PostPosted: Sat Aug 11, 2012 10:09 am
Using Rotors own BSA30 cups, you can run Rotor 3D+ on a BSA frame as well (just put such a Power2max on my Look 596 machine).
On their website, P2Max say this is the lightest crank of all their powermeters, didn't weigh mine, though :oops:
At the moment, I don't have any personal long term feedback on such a solution, either.
PostPosted: Sat Aug 11, 2012 10:55 pm
I own a rotor 3d+ power2max crankset and it's really nice. I would recommend you rotor cranks and you might want to reconsider the 3D+ version as it's lighter and theoretically stiffer than standard 3D one. It also fits bb386 standard and many others, so it might be a wise choice. BSA30 bearings by rotor are very good quality imho.
PostPosted: Sun Aug 12, 2012 12:14 am
Why not go for the lightning crank it is about 200$ more than the rotor and will save you over half a pound compared with the s900.
Sent from my PG86100 using Tapatalk 2
PostPosted: Sun Aug 12, 2012 12:54 am
I have 2 P2M on 2 Rotor 3D and I am very very happy with both set-up. One is standard 130 and the other one compact, both with Q Rings. Not the lightest out there but stiff, solid and easy to work with. Yes, you could save some weight going with the + version but for me, I was looking to put the money saved on both crank elsewhere. The P2M themselves are great and both have worked flawlessly. I could not recommend enough. Customer service is also outstanding.
Cheers,
C
Users browsing this forum: Bing [Bot], DamoRider, Google [Bot] and 47 guests
There are no new unread posts for this topic. Power2max bb30 crank (alternatives?)
tri
Mon Jul 23, 2012 10:45 pm
Beancouter View the latest post
This topic is locked, you cannot edit posts or make further replies. Power2max
mikefromcanmore
Sun Dec 30, 2012 7:13 am
Tillquist View the latest post
There are no new unread posts for this topic. Cervelo S2 and Power2Max...
parajba
Sun Oct 28, 2012 7:08 pm
Omiar View the latest post
There are no new unread posts for this topic. Bottom bracket for Rotor 3D with Power2Max PM
Frankie13
9
869
Fri Oct 26, 2012 8:30 am
madmole View the latest post
There are no new unread posts for this topic. Question: Power2Max and Garmin Sensor Compatibility
CerveloBert
Fri Nov 23, 2012 7:08 am
CerveloBert View the latest post
It is currently Thu Jun 20, 2013 4:20 am
