Post new topic Reply to topic  [ 6 posts ]
 Post subject: Romin Evo Pro squeek
PostPosted: Fri Aug 10, 2012 3:42 pm
Bought a new romin evo pro to replace my Fizik alante. Was pleasantly surprised at the comfort but after several hunded miles developed a sqeek with every pedal stroke that was gettin louder and louder. I called specialized and they said send it in and they would replace if found faulty. (I explained that I purchased it on internet from Specialized dealer) Recieved new saddle and after a couple hundred miles the new one sqeeks worse than the old one. The sqeek is coming from where the rear rails insert. I sprayed some silicone spray where the rails insert which is apparently the wrong thing to do for now EVERY pedal stroke you hear a LOUD cracking sound from the rail, much worse than before...... I think the silicone must have losened the adhesive. Anyway long story short has anyone else experienced this problem with these saddles?
 Post subject: Re: Romin Evo Pro squeek
PostPosted: Fri Aug 10, 2012 5:56 pm
I have seen this happen with many Specialized saddles,
most of the time I will drip some tri-flo into the slots where the rails are inserted and it takes care of it.
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Fri Aug 10, 2012 8:49 pm
The epoxy came loose on my evo pro in the front. I pulled it out and re-did the epoxy in all the holes. I used the same stuff I use on all my golf clubs but any 5 min devcon or gorilla 2 part epoxy will do. Will hold much better than the stock stuff they use. Saddle has been perfect ever since.
make sure to sand the surface lightly and clean with rubbing alcohol before applying the epoxy.
PostPosted: Fri Aug 10, 2012 9:07 pm
Get it replaced under warranty. Every time I have had an issue with a Specialized saddle they have happily replaced it.
PostPosted: Fri Aug 10, 2012 11:47 pm
I've owned three Romin Comp's and all of them eventually started creaking. Love the comfort in the saddle but I'm about to start searching for something new which doesn't make noise.
PostPosted: Sat Aug 11, 2012 4:42 pm
Just got the evo pro last week with the new carbon rail adapter for the Specialized single bolt seatposts. No squeaks whatsoever nor did my old romin expert have any. Maybe your rail clamps need to be replaced?
Users browsing this forum: CarlosFerreiro, Google Adsense [Bot], SvenNijs and 55 guests
There are no new unread posts for this topic. Going from Romin Evo Pro to SMP
digitalnorbs
Tue May 07, 2013 5:19 am
shimmeD View the latest post
There are no new unread posts for this topic. 2013 romin pro vs toupe pro
addictR1
28
1530
Mon Jun 10, 2013 11:56 pm
addictR1 View the latest post
There are no new unread posts for this topic. Specialized Romin vs Toupe etc
spud
Sun Jul 22, 2012 9:56 pm
neeb View the latest post
There are no new unread posts for this topic. Romin Pro Slipping - Any suggestions?
Dallez
10
765
Sat Jul 14, 2012 9:52 pm
Dallez View the latest post
There are no new unread posts for this topic. Enve Seat Post Romin Evo Pro Saddle
melbnut
Fri Dec 21, 2012 11:36 am
Ozrider View the latest post
It is currently Wed Jun 19, 2013 12:08 pm
