Post new topic Reply to topic  [ 7 posts ]
 Post subject: Laterally Stiff Wheelset
PostPosted: Fri Aug 10, 2012 3:36 pm
I've been trying to find an aero, laterally stiff wheel set, and that's some what light weight in that order, but I've been coming to a wash each time.
I've tried Zipp 101s and 303 Firecrests with Zipp 188 & 88 hubs and those are very flexy when I put lateral force on the brake track with my hands--meaning, if I push the rim of the wheel towards the brake pad it would easily touch (with greater than 5mm pad clearance!).
My friend has told me the Enve 45s laced to DT Swiss 240s do the same as well. Will the Enve SMART 3.4 tubulars laced 20/24 to Chris King R45 hubs do the same?
Anyways, what's the issue here? Am I overlooking something or are wheels supposed to flex that much from side to side? I don't get it.
PostPosted: Fri Aug 10, 2012 5:10 pm
The 3.4s laced to Alchemy hubs or Tune hubs will be laterally stiffer than CK or DT. When I build 3.4s I use Sapim Race on the drive side of the rear wheel. That build will be much better than other options mentioned.
www.ergottwheels.com
PostPosted: Fri Aug 10, 2012 5:37 pm
You are not missing anything. That is why some of us pay up and ride Carbonsport Lightweight Tubulars. No more flex.
PostPosted: Fri Aug 10, 2012 6:13 pm
So pushing the rim with your hands is the indicator and test for how stiff a wheel is?!?!
I can do that with any wheel, they are carbon fiber, not solid tempered steel.
But seriously, I believe the stiffer the wheel, when pedaling, the more it will move between the brake tracks.
Mavic Cosmic Carbone ultimate tubies are some of the stiffest out there.
I run Zipp 303 firecrest, pretty darn stiff.
If Big Tom Boonen can ride stock 404 FC...I'm sure they are good enough for just about anybody for stiffness, aero and ride quality.
PostPosted: Fri Aug 10, 2012 6:50 pm
He also said aero. :mrgreen:
PostPosted: Fri Aug 10, 2012 7:42 pm
as Zigmeister said, many here have a ill conceived notion on wheel stiffness.
Both a very stiff wheel and a very soft wheel will rub the brakes.
The difference is that a very stiff wheel won't deform as a soft wheel does, meaning a lateral force on once side creates a deflection to the opposite on the top side of the rim.
as for the Zipps, better make sure the preload is set correctly or they'll move quite a bit.
PostPosted: Fri Aug 10, 2012 11:35 pm
Forget the side to side, or at least place less of a priority on it. Wheels all deflect - they need to otherwise they would need to be incredibly over-built (heavy) to survive. The rotation rigidity is more important, as that is where your effort transfers & translates to forward movement.
Adrien's posting here (clipped from a previous repost) explains with more scientific basis (& a lot more experience) what you are raising question against.
viewtopic.php?f=3&t=97599&start=15#p834344
Users browsing this forum: Alexa [Bot], Bing [Bot], brearley, Exabot [Bot], jdott, Majestic-12 [Bot], Oswald, phlip, rijndael, StefanG and 60 guests
This topic is locked, you cannot edit posts or make further replies. Laterally stiff, mid-high carbon rear wheel
ultyguy
Thu Jul 12, 2012 9:49 am
ultyguy View the latest post
There are no new unread posts for this topic. Stiff and Cheap carbon tubular wheels ?
CeCa
Tue Jun 05, 2012 12:15 am
strobbekoen View the latest post
This topic is locked, you cannot edit posts or make further replies. alloy road clincher rim? stiff yet light?
durianrider
Mon Jul 16, 2012 10:16 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. zipps newest 202s are they stiff enough for field sprints?
JAX11
Tue Jun 19, 2012 3:16 pm
Zigmeister View the latest post
There are no new unread posts for this topic. What wheelset?
tenax
Fri Feb 15, 2013 9:34 am
superb View the latest post
It is currently Wed May 22, 2013 7:53 pm
