Post new topic Reply to topic  [ 6 posts ]
PostPosted: Wed Aug 08, 2012 5:22 pm
I decided to get a Power2Max powermeter, but I want to choose between S-works or Lightning crank. Both are compatible, but I have no experience with them in use and Specialized doesn't list actual weight of crankarms.
I would like to know if Lightning are worth extra price and what is the weight penalty of S-works.
PostPosted: Wed Aug 08, 2012 6:34 pm
More to the point, has anyone seen data indicating the Power2Max is accurate?
I was worried by Jeff Jones' test.
http://djconnel.blogspot.com/
Fuji SL/1
PostPosted: Wed Aug 08, 2012 7:34 pm
Attached is the accuracy profile of my one. At least it is consistent side to side as the one it replaced (they were very quick with a warranty) had a 2% difference when in the big dog (and was over reading by more).
I observed variation in accuracy (as I tested many times) on different occasions although part of that will be the granularity of the calibration figures.
http://www.speedtheory.co.nz
PostPosted: Thu Aug 09, 2012 5:17 am
im assuming you have a bb30 frame...
PostPosted: Thu Aug 09, 2012 11:07 am
It will be used for Specialized Transition with OS BB that I guess is a bb30 compatible, but I also would like to use it on my Scott CR1 Team Issue with bb adapter.
PostPosted: Fri Aug 10, 2012 1:48 am
well that pretty much answers the question for you. if you want to use it on a non-bb30 frame (your cr1), it has to be the lightning.
Users browsing this forum: -Robin-, Bing [Bot], Google [Bot], Google Adsense [Bot], justkeepedaling, Rob1519, timj and 61 guests
There are no new unread posts for this topic. Recommend Crank-Based Powermeter for BB30 Ui2 Compact
415brian
Fri Nov 02, 2012 8:43 pm
415brian View the latest post
There are no new unread posts for this topic. S Works sl3 crank choices
dayne
Thu Nov 01, 2012 1:49 am
wetpaint View the latest post
There are no new unread posts for this topic. New crank from Praxis Works
Ritterview
20
2941
Sat Oct 06, 2012 1:39 am
redhed18 View the latest post
There are no new unread posts for this topic. Attachment(s) Lightest BB30 powermeter
jainsworth123
Sat Apr 20, 2013 5:23 pm
JackDaniels View the latest post
This topic is locked, you cannot edit posts or make further replies. Attachment(s) S-WORKS Venge or S-WORKS Tarmac SL4
elliott123
Wed Feb 13, 2013 4:38 pm
elliott123 View the latest post
It is currently Sat May 25, 2013 4:29 pm
