It is currently Tue Jan 16, 2018 10:55 pm
Post new topic  Reply to topic  [ 7 posts ]
PostPosted: Wed Aug 08, 2012 12:44 am
I'd ask the man myself but I'd need to purchase a membership. :roll:
Anyway, it was time for new cleats so I figured I'd give his method a try. I went with method #1 and with my cleats slammed all the way forward, my BOF is 28mm in front of the pedal axle. I was hoping for ~10mm...
I'm using Pearl Izumi shoes at the moment which he states will cause problems for this method, but a full 28mm? Missing the mark by such a large margin makes me feel like I missed a step more than solely a shoe problem, but maybe I'm just in denial.
Are the mounting holes on Sidi, Shimano, Specialized, Lake, etc. significantly closer to the toe to correct this?
This is with SPD-SL cleats and 5700 pedals.
PostPosted: Wed Aug 08, 2012 1:05 am
The guy talks a little sense, but a lot of c***.
You get on your bike and your ride it, and you stop to make regular adjustments. You find the right cleat adjustment through 'feel'.
PostPosted: Wed Aug 08, 2012 1:22 am
AGW, I highly recommend paying the small fee and asking Steve himself.
You'll find his reply will go far and above what you're hoping for. He's very good.
VeloKicks
The Gram
The Men of Steel
PostPosted: Wed Aug 08, 2012 2:11 am
I find the "by feel" method works quite well. When (if) adjusting mine, I aim to have it setup such that the pedal feels "balanced" when applying torque.
Too far back --> foot further forward over axle --> foot tends to roll forwards --> tibialis anterious/ extensor digitorum longus muscle (I'm sure there are others deeper too controlling flexion of the foot) gets excessive work and will feel fatigued prematurely.
Example to try at home: stand on edge of a stair ledge on heels with toes hanging over edge. Move rotate ankle to move foot up and down by rolling on heel.
Too far forwards --> foot pushed back over axle --> foot tends to roll forwards --> soleus muscle tends to get excessive work (perhaps too the gastrocnemius) leading to premature muscle fatigue (sometimes can lead to tendinitis of the archilles tendon / cramp in calves).
Example to try at home: stand on the edge of a stair ledge on the balls of your feet and rotate the ankle slowly (a standing calf raise). Do this 20 times to full extension and you get the point.
Saddle setback/height also come into play too.
Cheers,
I
PostPosted: Wed Aug 08, 2012 4:21 am
Why not go to your local shop and get a fit?
PostPosted: Wed Aug 08, 2012 9:06 am
If I were you I'd just ride over to E 6th and N Fremont, walk into Fairwheel and ask for Maxim. He's very good.
Or you could hit wedofeet.
I would love to meet Steve Hogg, but when it comes to fit, local is just so much easier.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Wed Aug 08, 2012 10:53 am
Having had a pro fit with Steve 2 years ago and still reaping the rewards of the fit, just wanted
To reccomend paying the subscription, it's bugger all in the scheme of things and likely to yield the
Greatest benefit per dollar you are likely to find.
Best of all endevour to see him in person, high cost yes, high value absolutely.
To the individual who stated steve talks alot of crap and to do fit by feel;
It is apparent his ignorance of Steve's skill set an likely of his own shortcomings both physically and intelectually are staggering In their magnitude...
Attempting speak with authority about something you have no direct Experience of makes you appear
Ill informed and foolish....Open your ears in place of your mouth...
Best of luck to the OP.....
There are no new unread posts for this topic. Campagnolo SR ITA BB cups installation method
karhu
14
844
Mon Jul 03, 2017 11:15 pm
AJS914 View the latest post
There are no new unread posts for this topic. Shoes with cleat holes far forward?
C50DB
11
1201
Fri Jan 12, 2018 4:07 am
blamester View the latest post
There are no new unread posts for this topic. Cleat position when ur feet are not same length..
3Pio
9
818
Mon Sep 04, 2017 4:47 pm
3Pio View the latest post
There are no new unread posts for this topic. Giro Republic : Using 2-Bolt Cleat Mount with 3-Bolt cleats
gerryc89
Fri Jul 28, 2017 3:24 pm
TheKaiser View the latest post
Users browsing this forum: dricked, gewichtweenie, Google [Bot], Google Adsense [Bot], JohnHinMD, KarlC, topflightpro, Yahoo [Bot] and 44 guests
cron
