Post new topic Reply to topic  [ 5 posts ]
PostPosted: Tue Aug 07, 2012 3:39 pm
Hi all , i have a cerevelo s1 with funda pro fork, carbon steerer , alu sleeve inside, the alu sleeve slips up when tightening headet. Any remedy out there? frame purchased in april so warrantied i guess but shiuld this happen? Epoxy in the steerer do it? Cheers...
PostPosted: Tue Aug 07, 2012 3:47 pm
not quite clear, did you glue (epoxy) the sleeve, or did you not
it is a must to glue it in
PostPosted: Tue Aug 07, 2012 5:18 pm
I never bothered using the alu insert in my Funda forks. I ran for 2 years without it with no problems. However I did use a tall compression adjuster to preload the headset bearings:
http://www.chainreactioncycles.com/Mode ... fAodYBYAFg
Once the bearing preload was set and the stem clamped up tight, I removed the BBB and installed a Carbon-Ti X-Plug and X-Cap
CAAD9 | CAAD10
PostPosted: Tue Aug 07, 2012 7:39 pm
If it hasn't been epoxied in to begin with, do that. A sachet of the right compound is available as a spare part from 3T if it's missing.
I would use this system in every carbon fork I possible could. It supports the steerer far better than a conventional compressor and puts no outward pressure on the carbon steerer tube. The only downside is difficulty in trimming the fork down the track should you reduce your stack height.
PostPosted: Tue Aug 07, 2012 10:38 pm
If the 3T glue packet is unavailable, Dev Con 2 ton epoxy works fine for this purpose. The ID of the fork should be sanded lightly with 240ish paper, then it and the sleeve cleaned with rubbing alcohol prior to applying the epoxy. Place the fork upside down and allow the epoxy to cure.
Monkeyburger
http://ocdlikeme.blogspot.com/
Users browsing this forum: airwise, Bing [Bot], Google Adsense [Bot], hornedfrog, Majestic-12 [Bot] and 46 guests
There are no new unread posts for this topic. Romin Pro Slipping - Any suggestions?
Dallez
10
763
Sat Jul 14, 2012 9:52 pm
Dallez View the latest post
There are no new unread posts for this topic. Easton EC90 seatpost slipping
HugoDrax
16
502
Tue Mar 12, 2013 5:33 pm
HugoDrax View the latest post
There are no new unread posts for this topic. "Slipping" headset
bontie
Fri Sep 28, 2012 6:44 am
bontie View the latest post
There are no new unread posts for this topic. Fork expander för Colnago fork ?
PSM
Thu Nov 22, 2012 11:03 am
PSM View the latest post
There are no new unread posts for this topic. New fork for TI frame
skiezo
19
1067
Sat Mar 30, 2013 5:47 pm
la rosa View the latest post
It is currently Tue Jun 18, 2013 6:26 am
