Post new topic Reply to topic  [ 9 posts ]
 Post subject: Dura Ace BB
PostPosted: Mon Aug 06, 2012 5:54 pm
Anyoneknow why my Canyon CF should chew through a BB in 3 months?
 Post subject: Re: Dura Ace BB
PostPosted: Mon Aug 06, 2012 7:26 pm
Chew through as in the bearings? Could have been set too tight
PostPosted: Mon Aug 06, 2012 8:19 pm
Maybe. The bearings creek. It is difficult to set the torque on the end-cap of the crank. Any suggestions?
PostPosted: Mon Aug 06, 2012 8:27 pm
Is the BB shell parallel? Many frames don't come with the shell accurately machined causing premature BB failure.
If your shell is alloy with no carbon covering the faces it can be checked/machined by a decent bike shop. Of course, some carbon frames can be damaged by this machining so take it to someone who knows what they're doing.
PostPosted: Mon Aug 06, 2012 8:31 pm
Are you one hundred percent sure the creak comes from your bottom bracket? With Canyon, usually creaks are coming from: dry quick releases, seatpost (remove, regrease, reinstall), saddle rails (add a little bit of oil). When nothing of this fixes the problem, reinstall bottom bracket with lots of assembly paste or grease.
PostPosted: Mon Aug 06, 2012 9:49 pm
Are the bearings on HollowTech2 setups particularly sensitive to the torque you place on the installation thumbwheel? Put my first set on a bike last week and it occurred to me that I had no idea whether I was doing it to spec or not.
PostPosted: Tue Aug 07, 2012 8:40 am
It does not creak, but makes a grinding noise when pedalling.
PostPosted: Tue Aug 07, 2012 4:58 pm
Not the BB! Front wheel bearings are the suspect...
PostPosted: Tue Aug 07, 2012 5:01 pm
Same thing, you definitely set them too tight. Wore away at the bearing
Users browsing this forum: AndrewL, Bing [Bot] and 58 guests
There are no new unread posts for this topic. Dura Ace 9070 Di2
Horacio
Fri Nov 30, 2012 7:56 am
SvenNijs View the latest post
This topic is locked, you cannot edit posts or make further replies. Dura Ace Di2 from Ultegra Di2
DamoRider
Sun Jan 27, 2013 8:36 pm
DamoRider View the latest post
There are no new unread posts for this topic. Cervélo S2 - Dura-Ace DI2
bruno2000
Fri Jul 27, 2012 3:16 pm
bruno2000 View the latest post
There are no new unread posts for this topic. Dura Ace C35 clincher
PoorCyclist
38
7442
Tue Dec 11, 2012 7:15 pm
CBJ View the latest post
There are no new unread posts for this topic. Buying used Dura Ace WH-7850-C24-CL
BTM
15
2222
Sat Sep 01, 2012 1:14 am
BTM View the latest post
It is currently Sat May 18, 2013 6:21 pm
Shimano Dura-Ace components & groupset at reasonable prices
