It is currently Fri Jan 19, 2018 10:54 am
Post new topic  Reply to topic  [ 15 posts ]
PostPosted: Sun Aug 05, 2012 9:49 pm
Was using Vittoria Rubino Pro.Bought the 2 at the same time so presumably from the same batch.
Long story short but on my 1st ride at correct psi the 1st tyre split on smooth road. Sh1te happens I thought to myself. Then a couple of hundred kms later the other split again on a very smooth road.
Dropped an email to the shop and they without any questions refunded me.Bad batch I thought to myself.
Then this eve I noticed on the Ultremo's I picked up that there was another split in the rubber. Again was under the max psi .I had the tyre at 135 psi.
WTF is going on?????
PostPosted: Sun Aug 05, 2012 10:29 pm
Pics? Why are you riding at such a high pressure? What is your setup? Rims, tube, rim tape, bike, weight etc....
Being vague doesn't help anybody answer your question..
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Sun Aug 05, 2012 10:49 pm
Why am I riding at such a high pressure?
The reason I like the Vittoria's is the fact you cam pump them up and I love them that way. Plus when I left the front wheel in for a spoke to be replaced on the Khamsin in my lbs he whacked the Vittoria up to 140 and said that they are best that way. He rides the same roads as me.
Will upload the pics in a bit.
PostPosted: Sun Aug 05, 2012 11:07 pm
what do you weigh? running pressures that high unless you are super big does not make a lot of sense.
PostPosted: Sun Aug 05, 2012 11:14 pm
I am super big. 95kg and proud :lol:
 Post subject: GAAAHHHHHHHH! MYTYRES
PostPosted: Sun Aug 05, 2012 11:34 pm
120psi is plenty for a 200lb'er....however, don't think that fully explains your tire busting.
Mosaic RS-1
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=138478
Cielo by Chris King Cross Racer
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=134376
PostPosted: Sun Aug 05, 2012 11:42 pm
Definitely more to it than tire pressure but you should reduce. As Btompkins indicated around 120psi is better. Ou want your tire to be able to comfort to irregularities of the road rather than deflect off them...
Flickr
Follow on Instagram
PostPosted: Sun Aug 05, 2012 11:47 pm
I have also posted this in another forum and it has been suggested that my pump gauge maybe out.
Its a possible explanation!!!!!!!
I will post pics tommorrow (its late and I have work in the morn :cry: )
PostPosted: Sun Aug 05, 2012 11:56 pm
Popcorn ready....let the fun begin!
:smartass:
PostPosted: Mon Aug 06, 2012 9:57 pm
Just an update.
The Rubino's split was a complete failure ie the thread and the carcass had split and was revealing the tube.
On inspection during full daylight of the Ultremo's - the inner casing was fully intact and it was just the outer rubber had split. Have reduced the ultremo's now to 120.
PostPosted: Tue Aug 07, 2012 12:39 am
And the cause? :popcorn: :popcorn: :smartass:
Flickr
Follow on Instagram
PostPosted: Tue Aug 07, 2012 10:22 am
You do realize that adding your own weight on top of those 135psi, actually increases the pressure even more. So you at 95kg at 135psi is not the same actual tire pressure as somebody 75kg riding 135psi. Think of it like filling a waterballoon nearly full and then squeezing it 'til it bursts...
You need to use wider tires, 25-28mm at your weight, so you can lower the pressure without getting snakebites. 23mm isn't for everyone.
The Shivenge
PostPosted: Tue Aug 07, 2012 1:41 pm
Pressure is pressure. Doesn't change based on how much someone weighs. But I agree that he needs wider tires and lower pressures.
PostPosted: Tue Aug 07, 2012 3:30 pm
In the case where the tire is filled to the point where it really doesn't deflect under pressure, doesn't squeezing it increase the pressure per square inch. The tire will try do deflect but there is just nowhere for the air to go, thus the tire will burst.
Think of it like placing a football in a vice grip, and squeezing it.
The Shivenge
PostPosted: Tue Aug 07, 2012 7:14 pm
Ok.So lower pressures and wider tyres for fat boy. Got it. :lol:
There are no new unread posts for this topic. Vittoria Corsa G+ TLR ?
lyrictenor1
9
894
Fri Aug 04, 2017 4:23 pm
3Pio View the latest post
There are no new unread posts for this topic. PSA: Wiggle Vittoria Open Pave CG - $33
Pschnei3
Tue Sep 12, 2017 5:33 pm
Pschnei3 View the latest post
There are no new unread posts for this topic. Vittoria Pave replacement 2018
uraqt
Sun Dec 31, 2017 3:22 am
Sammutd88 View the latest post
There are no new unread posts for this topic. Vittoria Corsa G+ tubular leaking air from sidewalls...
3Pio
Mon Oct 30, 2017 8:00 pm
There are no new unread posts for this topic. Vittoria Corsa Elite tubular tire
3Pio
22
1586
Mon Oct 23, 2017 9:19 am
themidge View the latest post
Users browsing this forum: beeatnik, Bing [Bot], CarlosFerreiro, Miller and 32 guests
