Post new topic Reply to topic  [ 4 posts ]
PostPosted: Fri Aug 03, 2012 10:47 am
My left ST-7900 suddently won't downshift properly. I can shift upwards as much as I want, but when I press the downshift lever nothing happens if I don't manually press down the small part with the pink arrow in the middle of the first photo. After pressing it down (like seen on the second photo) it works fine UNTIL i upshift next time. Any ideas? A dead spring? If so, can it be replaced?
Canyon Ultimate CF SLX
PostPosted: Fri Aug 03, 2012 1:51 pm
WD40 blown through my old STi shifters helps downshifting. I presume your ratchet mechanism is lightly lubricated.
Just to be sure, by 'downshifting' you are referring to letting out cable thereby releasing cable tension at the derailleur, and moving to the smaller cassette cogs...correct?
PostPosted: Fri Aug 03, 2012 2:54 pm
Yeah, that's what I mean. Isn't "downshift" the correct word?
I've already tried the WD40 trick, but it didn't work. Any other ideas? Is there any replaceable springs in there?
PostPosted: Fri Aug 03, 2012 6:05 pm
I have had exactly the same problem last fall and I couldn't fix it unfortunately. I had to buy another lever.
Users browsing this forum: Anders, Bing [Bot], Exabot [Bot], Google [Bot], Kayrehn, madmartigan and 34 guests
There are no new unread posts for this topic. Is Dura Ace 7900 only mediocre?
mattcooke
19
1608
Thu Feb 21, 2013 11:43 am
PSM View the latest post
There are no new unread posts for this topic. Dura Ace 7900 hub adjustment
mikegrad
Mon Aug 13, 2012 2:00 pm
oreoboreo View the latest post
There are no new unread posts for this topic. SRAM red 2011 or Dura ace 7900
mattlawro
16
1792
Tue Oct 16, 2012 11:07 pm
53x12 View the latest post
There are no new unread posts for this topic. YAWT: Nimble Fly, Dura-Ace 7900, or ???
BTM
Thu Sep 13, 2012 4:52 pm
BTM View the latest post
There are no new unread posts for this topic. Attachment(s) Tuned Dura-ace 7900 group.
[ Go to page: 1 ... 4, 5, 6 ]
kevosinn
79
7297
Tue Jan 22, 2013 10:49 pm
Wcl4 View the latest post
It is currently Sat May 18, 2013 11:22 am
