Post new topic Reply to topic  [ 16 posts ]
Go to page 1, 2  Next
PostPosted: Wed Aug 01, 2012 4:42 pm
We own three Campa 10 sp equiped bikes and 6 pairs of wheels (and my brother another bike with three pair of wheels). My competition bike is equiped with Chorus 2004 which works absolutely fine. I wanted to change towards the new style shifters, but that gave me two viable options:
1. Convert all three bikes. Simply to expensive and a big waste of perfectly good parts.
2. Try Veloce/Centaur Q-Shift brifters. The q-Shift didn't make this a nice option, furthermore, there has been some odd backward compatibilty breakage in the ten speed (weaker spring in the rear derailleur).
Enter JTEK Shiftmate! Our LBS installed the brifters (kept the 2004 rear derailleur), aded a Jtek Shiftmate I imported (props to my LBS who loved the experiment). And it worked! Of course I should have known it would work, but it's always a relieve.
In the words of my LBS:
"Dang, it works absolutely perfectly"
A huge thumbup for Jtek. Now I can do the swap to 11 speed incrementally! :thumbup:
PostPosted: Wed Aug 01, 2012 10:52 pm
I want to try one of these so I can run campy shifters and mechs with a shimano cassette and a shimano hub for the drive side to hub centre spacing.
www.thecycleclinic.co.uk
PostPosted: Thu Aug 02, 2012 12:56 am
ShiftMate model #2 http://jtekengineering.com/shiftmate.php I presume: Campagnolo 11 speed shifter + Campagnolo derailleur + Campagnolo 10 speed cassette.
PostPosted: Thu Aug 02, 2012 1:26 am
No-one reads a post that has a title containing the word 'brifters'.
PostPosted: Thu Aug 02, 2012 1:28 am
Well, I don't know if you read it, but you posted in it.
PostPosted: Thu Aug 02, 2012 2:50 am
I think the term is acceptable to most of us.
r o y g b i v
PostPosted: Thu Aug 02, 2012 3:39 am
There is no jtek for you... because it is almost a perfect match without one... for S10 cassettes. You might need to move the cable out from the fixing bolt a hair, in a less extreme Hubbub mod.
Heck, just put a Shimano rear derailleur on (I'm partial to the shiny 7700 model) a 9spd S cassette and chain, and you don't need a jtek or anything. For a 10 spd S cassette one of the jteks would work.
formerly rruff...
PostPosted: Thu Aug 02, 2012 4:09 am
I second the "less extreme hubbub mod"
I'm using exactly the setup you mentioned to run Campy 10 speed cassette with Dura Ace 9 Shifter and rear mech. Dropped right in without resetting the limit screws.
PostPosted: Thu Aug 02, 2012 4:39 am
Indeed. Hardly a surprise it worked, but I couldn't find many real world experiences. Thought I add mine for the community :wink:
PostPosted: Thu Aug 02, 2012 4:41 am
Strangely enough a mod changed it, so obviously it's not done to call it a brifter. Could have called it a n Ergo I guess :beerchug:
PostPosted: Thu Aug 02, 2012 5:20 am
WMW's information apparently pertains to Campagnolo 11 shifters.
But if bm0p700f wants to use Campagnolo 10 shifters, then ShiftMate model #1 http://jtekengineering.com/shiftmate.php Campagnolo 10 speed shifter + Campagnolo derailleur + Campagnolo 10 speed cassette. Or if additionally, bm0p700f swaps out to Shimano derailleur, then ShiftMate model #3. As of 2007 (vintage equipment), Jtek surmised that the Shimano derailleur with Shiftmate model #3 should perform slightly better than Campagnolo derailleur with ShiftMate model #1 on account of the Shimano derailleur being stiffer. However, this surmisal was not based on testing, and reflected the equipment of the era (DA 7800 derailleur, Campagnolo Record 10 derailleur).
PostPosted: Thu Aug 02, 2012 9:03 am
he he.
If I were a mod I'd delete all posts that misuse adverbs. Now THAT would be sensible.
r o y g b i v
PostPosted: Thu Aug 02, 2012 5:26 pm
Absolutely. The new hoods are so much better, and you need Chorus shifters or better to get multiple gear changes in both directions.
formerly rruff...
PostPosted: Thu Aug 02, 2012 5:28 pm
budgetweenie wrote:
I second the "less extreme hubbub mod" I'm using exactly the setup you mentioned to run Campy 10 speed cassette with Dura Ace 9 Shifter and rear mech. Dropped right in without resetting the limit screws.
A 9spd shifter will shift 10 gears?
formerly rruff...
PostPosted: Fri Aug 03, 2012 2:52 am
Only shifts 9, accurately. The limit screw settings include the top cog but won't engage the lowest.
Post new topic Reply to topic  [ 16 posts ]  Go to page 1, 2  Next
Users browsing this forum: 1415chris, asv, Rappid, TrekUk and 64 guests
There are no new unread posts for this topic. Attachment(s) Best bar shape for Campagnolo Chorus 11 shifters?
giro di lento
20
1528
Tue Jul 17, 2012 9:33 pm
reggiebaseball View the latest post
There are no new unread posts for this topic. Chorus cassette
wasabi1
Thu Aug 09, 2012 11:05 pm
wasabi1 View the latest post
There are no new unread posts for this topic. Chorus FD on Record gruppo?
MaxDaddy
10
595
Sun Feb 24, 2013 10:11 pm
MaxDaddy View the latest post
There are no new unread posts for this topic. campagnolo 11 sp chorus front der HELP!
digitalnorbs
7
400
Sat Aug 25, 2012 3:09 am
There are no new unread posts for this topic. 11 speed chorus front derailed set up
digitalnorbs
Sun Jul 01, 2012 1:41 pm
DaveS View the latest post
cron
It is currently Sat May 18, 2013 9:07 pm
