Post new topic Reply to topic  [ 2 posts ]
PostPosted: Wed Aug 01, 2012 11:45 am
I remember seeing it before, but for the life of me, I just can't seem to pull it up in a search.
So, I have Campy UT cranks on a bike w PF30 shells, using Campy adaptor cups. However, because the BB shell is 67.XXmm while the crank arms allow for up to 69mm of BB shell, one of the adaptor cups has worked its way out by around 1.5mm. Crank arms are properly tightened. Tapping in the cup is a fix only for a couple hundred miles.
If I am not mistaken, I just need to track down some thin spacers with OD of 46mm, to be placed between the ND cup and the frame BB shell. Where can one get these?
Thanks.
Fast falcons: http://www.youtube.com/watch?v=j3mTPEuFcWk" onclick="window.open(this.href);return false;
twitter: Falco_bike
Facebook: falco.bike
PostPosted: Wed Aug 01, 2012 1:24 pm
It seems as though you are expecting that the UT crank and bearings job is to hold the cups in place.
Wrong. Very wrong.
If the BB shell width is within spec (68 +/- 0.8), then the answer is loctite on the cups. I have not needed to this personally, but there's threads discussing the issue.
dangerous curves ahead
Users browsing this forum: dha, Wookieopolis and 59 guests
There are no new unread posts for this topic. PF30 install?
audiojan
Tue Oct 16, 2012 5:10 am
elviento View the latest post
There are no new unread posts for this topic. Removing PF30 adapter, need the wisdom of WW!
audiojan
Sun Apr 14, 2013 6:22 pm
audiojan View the latest post
There are no new unread posts for this topic. Specialized Crankset on another PF30 frame?
Briscoelab
Sun Sep 16, 2012 4:05 am
There are no new unread posts for this topic. Make your SRM work on your PF30 frames!
ParisCarbon
14
1657
Sun Jan 13, 2013 8:09 am
NiFTY View the latest post
There are no new unread posts for this topic. PF30 bearing seal removal
styrrell
Sun Mar 24, 2013 9:03 pm
styrrell View the latest post
It is currently Sun May 19, 2013 9:58 pm
