It is currently Wed May 24, 2017 1:40 am
Post new topic  Reply to topic  [ 11 posts ]
 Post subject: Colnago size
PostPosted: Mon Jul 30, 2012 9:02 am
Hi
Im thinking of buying a Colnago Master. Im 185 tall with a inseam of 82cm. So my upperbody is relatively big. My problem is that if I want a frame with a long toptube matching my upperbody, the frame will be pretty big for the rest of my body, and I will have to lower the seatpost to much.
Which size Colnago would fit me. Im thinking of a 57cm Colnago Master with a 55.7cm toptube. Can I compensate the toptube length with a longer stem without ruining the overall bikefit?
Best regards Christian
 Post subject: Re: Colnago size
PostPosted: Mon Jul 30, 2012 9:33 am
You should be fine with a 57. Colnago's usually have short toptubes and having a longer stem is favoured by many.
PostPosted: Mon Jul 30, 2012 10:02 am
Christian,
when I was choosing my Colnago frame size I've sent an email directly to Colnago with my measurements (from Competitive Cyclist bike fit) asking them for a perfect frame size for me.
They replied and suggested a frame and stem size. I bought exact size they recommended and never had any issues with fit... perfect I would say.
Btw, I am 183cm tall and I ride 54s (same as 58 traditional) Colnago EPS.
It makes sense to ask manufacturer, of the frame you are after, for a fit/size recommendation.
After all they should know the best how's their frame supposed to fit someone in order to achieve best balance of performance and comfort.
PostPosted: Mon Jul 30, 2012 11:50 am
I just checked my inseam - its 86cm.
PostPosted: Mon Jul 30, 2012 2:13 pm
I'm also 185 cm tall and have owned many 59 traditional Colnagos that I'm happy with using 12 cm stems, saddle setback about 8.5 cm and bar drop about 9 cm. I've also ridden a 60 that was OK but seemed slightly long in the head tube so a little higher than the 59. 57 sounds way too small to me.
PostPosted: Mon Jul 30, 2012 3:19 pm
Jim - I think it depends on age and agility. There are plenty pro's of your height that will ride 56's. I think a 57's ok, but even if I was 185 myself I wouldn't go higher than a 58.
PostPosted: Mon Jul 30, 2012 4:03 pm
Probably a bad idea to ask the general public for sizing.
Best bet is to checkout out the geometry charts first,
Then look into a road bike frame calculator.
Actually check a few of them out.
Then if you are lucky enough you can try the bike shop and try one for size.
It's unlikely they will have your size or the frame you want.
Ultimately it is the position on the bike that will factor in the frame size.
I also always opt for one size smaller rather than one size bigger.
For the ultimate fit get custom.
PostPosted: Mon Jul 30, 2012 5:08 pm
As you've no doubt gathered by now sizing advice over the internet is pretty pointless especially if you're not really even sure where to start. I've seen plenty of "professional fits" that had me thinking "and you paid money to get that fit?". There are good ones too, but take the advice with caution. Always ask yourself if what the fitter is telling you makes sense and is applicable to you.
I'm 185cm, 91cm inseam, 803mm saddle height. I ride a 61 traditional with a 130mm, 6 degree stem. Slightly over 8cm of saddle to handlebar drop and use classic shaped bars.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Mon Jul 30, 2012 10:14 pm
Read as much as you can. Use your overall height with saddle height to determine frame height if your proportions are close to avg. Check the old CONI manual or another respectable source for avg. stem sizes for a given frame size, and then figure out how much drop you are comfortable with (probably between 7-9cm). With that information you should be able to get pretty close to your ideal fit. Long legged people tend to get smaller than avg. frames and short legged avg. to slightly bigger. Sloping frames are usually a good fit if you are long in the torso.
PostPosted: Thu Mar 28, 2013 11:01 am
[quote]
PostPosted: Thu Mar 28, 2013 11:43 am
4 lines that sum it all up, brilliant
There are no new unread posts for this topic. Colnago Master frame size question
stam1668
Sun Jan 29, 2017 12:29 pm
kgt View the latest post
There are no new unread posts for this topic. Colnago Super vs Colnago Master X-light
Kupepe
Tue Jan 10, 2017 8:19 am
Zakalwe View the latest post
Kupepe
Sun Jan 08, 2017 6:57 pm
Kupepe View the latest post
There are no new unread posts for this topic. Crank arm size
WhyZ
Sat Feb 18, 2017 10:20 am
Kayrehn View the latest post
There are no new unread posts for this topic. Chainring size efficiency
alcatraz
12
1460
Tue Oct 11, 2016 12:59 pm
Marin View the latest post
Users browsing this forum: Bing [Bot], CrankAddictsRich, JS300, kookie, Majestic-12 [Bot], MRM and 39 guests
