Post new topic Reply to topic  [ 37 posts ]
Go to page Previous  1, 2, 3
 Post subject: Re: Sanding an AX fork
PostPosted: Sat Dec 29, 2012 4:53 am
SWijland wrote:
Carbolift sucks
It doesn't suck - its just "weak".
What I mean is, I'm stripping paint from a carbon Redline frame and the paint-job is multi layers ..and thick!
I seemingly had 5 layers of clear->paint->clear->decals->clear to eat through.
it seems like it didn't do a damn thing but I had to keep reapplying the goo (5 times I think) to get down to the carbon.
it does suck from the effort but I know first hand that sanding also takes a looooot of time.
PostPosted: Sat Dec 29, 2012 2:46 pm
CarpetFibre wrote:
I'm trying to remove paint from an AX Lightness fork ... Do I run the risk of sanding the carbon and affecting the structural integrity of these forks?
Under absolutely no circumstances would I ever, EVER, recommend anyone actually ride an Ax fork.
Do these forks have structural integrity to spare?
PostPosted: Sat Dec 29, 2012 4:08 pm
I was thinking the same thing after I saw madcows post .
I like to have known what happened . It sounds like it was quite bad .
How are the forks holding up? My fav forks.
PostPosted: Sat Dec 29, 2012 4:33 pm
They're holding up fine. I can understand why people are scared by them though. They flex an awful lot in the plane of movement. It makes for a really smooth ride but when descending the steep and bumpy hills round here you can look down and see the front wheel wobbling back and forth. That said, they are stiff in the perpendicular plane to movement, climbing or accelerating out of the saddle feels more or less like any other forks.
Disclaimer: I weigh 58kg and don't really fling my bike around much.
PostPosted: Mon Dec 31, 2012 5:25 am
Could someone please elaborate on the razor technique? Is it a blade-forward or blade backside swipe? How much pressure? Etc.
I always sanded carbon products very very carefully (time consuming), so this thread of interest. Thx
PostPosted: Mon Dec 31, 2012 6:27 am
You may refer to this thread:http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=110609&start=60, see "1spd"'s reply. It seems that the optimal technique is to hold the blade perpendicular to the surface and drag back and forth. I've sanded some parts, but sanding is painfully slow even by using #150 sandpapers, so I only removed decals, not all clear coat. I then tried scraping according to 1spd's suggestion, it was really easy and the damage to carbon layer appeared to be minimal.
PostPosted: Mon Dec 31, 2012 7:02 pm
very helpful, i'll have a go at it!
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2, 3
Users browsing this forum: vladoo, VMac, Wookieopolis and 57 guests
There are no new unread posts for this topic. Thomson bars are here (pics page 2)
FastforaSlowGuy
22
1847
Sat Apr 06, 2013 2:56 am
Quinn039 View the latest post
There are no new unread posts for this topic. Innertubes as shifter hoods. now w/ pics page 1 scroll down
mdeth1313
33
2527
Sat Mar 16, 2013 5:18 am
Wingnut View the latest post
There are no new unread posts for this topic. WoundUp Carbon Fork, Matte Finish, Looking for Pics?
Snicks
Mon Oct 08, 2012 3:51 pm
Snicks View the latest post
There are no new unread posts for this topic. Stem and handlebar sanding
Husum
16
1106
Fri Apr 19, 2013 9:12 am
maddog 2 View the latest post
There are no new unread posts for this topic. Sanding clear-coated aluminum?
thegunner
Mon Dec 03, 2012 5:33 pm
thegunner View the latest post
It is currently Sat May 18, 2013 8:43 pm
