Post new topic Reply to topic  [ 10 posts ]
 Post subject: Keo Blades
PostPosted: Sun Jul 29, 2012 6:02 am
Does anyone know how to get the replacement carbon blade for the Keo Carbon Blades? Mind broke. Also how much does it weigh?
 Post subject: Re: Keo Blades
PostPosted: Sun Jul 29, 2012 6:21 am
Was it your fault? If no...
Warranty it, don't spend money on a replacement. If its out of warranty, push it until they give you a new spring.
PostPosted: Sun Jul 29, 2012 9:36 am
Go to a bike shop that is a Look dealer? :noidea:
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Sun Jul 29, 2012 2:55 pm
you can buy it as spare part
http://www.ribblecycles.co.uk/sp/road-t ... OOKPEDZ330
PostPosted: Sun Jul 29, 2012 3:03 pm
I wonder why those would break. :noidea: :smartass:
PostPosted: Sun Jul 29, 2012 7:31 pm
http://www.ribblecycles.co.uk/sp/road-t ... OOKPEDZ330" onclick="window.open(this.href);return false;
But can you then fit it without the proprietary tool that only distributors have?
PostPosted: Sun Jul 29, 2012 7:43 pm
Your local bike shop will have to send it in to Look. I think they charge $20 or so for installation.
PostPosted: Mon Jul 30, 2012 7:48 am
Ive replaced (swapped) blades without any special tools. All i did was remove the hinge pin for the rear "door". Personally i cant see what a special tool would do, its so easy to get the pin out.
PostPosted: Tue Jul 31, 2012 12:06 am
I've broken mine 3 times in two years. Sent back to look under warranty all 3 times. I personally think it's a poor design for this reason and have gone back to Keo Max Carbon on all my bikes. I have the blades as backups but doubt I'll ever use them, since the Keo Max 2s are pretty much bulletproof.
PostPosted: Tue Jul 31, 2012 11:53 pm
You send it to the Look distributor in CA along with $25 and they do it for you. The catch is you can't send it if you are not an authorized dealer.
Users browsing this forum: Bing [Bot], Google Adsense [Bot], shoopdawoop, tommasini and 60 guests
There are no new unread posts for this topic. Mavic CX01 Blades
ttlund
Sat Feb 02, 2013 11:54 am
ttlund View the latest post
It is currently Tue Jun 18, 2013 4:40 am
