Post new topic Reply to topic  [ 20 posts ]
Go to page Previous  1, 2
PostPosted: Mon Jul 30, 2012 6:32 pm
That's the whole point. Will it have enough capacity to be able to accommodate the 53/29 situation. We all know you should never find yourself in that combination but it's nice to know that if it did occur (forgetfulness, carelessness, etc) that it isn't going to rip your derailleur apart and break the hanger and end up destroying who knows what else in the process.
I have installed and ridden a drive chain combo that would not be recommended, but in order to accommodate certain situations temporarily I just used caution in the range that could have caused problems. But I would never run a combo that even allows the possibility of crossing the big ring with the big sprocket without enough capacity in both gain length and the derailleur.
The new 11speed derailleur has one cage than accommodate (providing chain length is correct) any combination of cassettes from 11/23 to 12/29 which is nice. The early generation 11speed derailleurs however require a slight modification and part swap to accommodate the 12/29. But the part is relatively cheap, like $15 or something.
But this thread is talking about 10speed capacity.
My Colnago C59
My Special Colnago EPQ
PostPosted: Mon Jul 30, 2012 10:39 pm
Tubbie Guru
Hi,
thisisatest wrote:
The medium cage is specifically designed for the 29t cassette. Actually should not be used w a cassette smaller than 26t. Its capacity is fully capable of handling the full range with a double, unlike the short cage which is a bit of a crapshoot when running the 29t.
The Record 10S medium cage derrie should and will run any cassette from 29T down without a glitch running a standard 39/53 crank.
The long cage should take all available cogs. The main reason it isn't used much is that it is slightly slower in responding to gear changes and of course it is heavier and less stiff. Other than that it also requires a longer chain which once again adds weight.
Ciao, ;)
PostPosted: Tue Jul 31, 2012 4:25 am
yup, it appears you are correct. i just reread an old campy catalog and it seems that, many moons ago, i misread what they were saying.
PostPosted: Tue Jul 31, 2012 6:19 am
Properly set up gears should be fine. I have never ripped a rear derailleur as a result with the big ring and the biggest rear cog. I have done this on 8 9 and 10 speed. I'm just stating my experience here. You do not need to do the same.
PostPosted: Tue Jul 31, 2012 4:45 pm
Durace but same concept on Wiggins bike
A 10 speed Shimano Dura Ace Di2 transmission with wide ratio cassette and longer cage rear mech for the mountains.
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
Users browsing this forum: Google [Bot], highwater, russianbear, timeforheroes and 41 guests
There are no new unread posts for this topic. Super Record 11 Rear Mech Failure - any others out there ?
lycralout
21
1508
Mon Sep 24, 2012 5:11 pm
Powerful Pete View the latest post
This topic is locked, you cannot edit posts or make further replies. Campag Record 10sp rear mech on 11sp set up
stuarts
Mon Feb 18, 2013 10:48 pm
stuarts View the latest post
There are no new unread posts for this topic. Tuning a veloce rear mech a special bolt sourcing question
bm0p700f
Wed Jan 16, 2013 11:36 pm
bm0p700f View the latest post
There are no new unread posts for this topic. 7900 dura ace rear mech
mec287
Fri Jan 18, 2013 3:03 pm
eric View the latest post
There are no new unread posts for this topic. Really specific Dura Ace front mech question
thisisnotaspoon
Sat Feb 09, 2013 7:56 pm
thisisnotaspoon View the latest post
It is currently Mon May 20, 2013 5:08 am
