It is currently Fri Jan 19, 2018 1:14 am
Post new topic  Reply to topic  [ 4 posts ]
PostPosted: Wed Jul 25, 2012 9:20 pm
I have had to rebuild the rear wheel of my Mavic Helium tubular classic wheel set (circa 1996)
Initially I did not have a tension meter but this time I have Park Tool Tension meter.
The manufacturer Mavic recommends the following tension:
Front and Rear non-drive side set to 92 kfg
Rear drive side 112 kfg
Now I have two sets of the same wheels. When I check the tension on the rear wheel of the other set I get the following tension readings:
Rear non-drive side to 90-110 kfg
Rear drive side 120-140 kfg
This seems to be somewhat substantially higher than what the manufacturer recommends but I also know that
90-112kfg is definitely not as stiff as the current wheels I have.
I do know that these are basically the same as the Mavic reflex rims except in red and with
different hubs, spokes (straight pull), spoke holes (26 front 28 back) and lacing patterns.
The front and the rear non-drive side is radially laced and the drive side are 3 cross.
If anyone has built these before please let me know about the tension.
Thanks
PostPosted: Sun Jul 29, 2012 5:19 am
They build fine with the tension set to
Be sure to use some grease on the threads and the nipples that face the eyelets.
It will make truing a snap.
PostPosted: Sun Jul 29, 2012 5:22 am
Thanks Stella-Azzurra you're the best! :thumbup:
PostPosted: Sun Jul 29, 2012 11:28 pm
Spoke tension is not related to the stiffness of the wheel (from a certain level of course, slack spokes obviously make for a very weak wheel). In fact, increasing spoke tension beyond "normal" levels increases the risk of failure since you are preloading all the components with unnecessary loads.
Other than that, I'm not a very experienced wheel builder, so I wouldn't know whether the tension you're using is any good for that particular wheel.
There are no new unread posts for this topic. Shimano cassette body for Mavic R-SYS SLR 2015 wheel
Tillquist
Tue Jun 27, 2017 6:26 am
Tillquist View the latest post
There are no new unread posts for this topic. Why doesn't the XR4 and Madone have a protected rear wheel?
Shrike
7
1499
Fri Jan 20, 2017 6:29 pm
naambezet View the latest post
There are no new unread posts for this topic. Caad9 rebuild
calv1n
Tue Nov 28, 2017 8:38 pm
topflightpro View the latest post
There are no new unread posts for this topic. Fork length Ridley Helium SLX fork?
Beaver
Mon Jul 17, 2017 5:31 pm
Beaver View the latest post
There are no new unread posts for this topic. 1980~ Steel classic.
Littlemad
Tue Nov 21, 2017 11:50 am
Littlemad View the latest post
Users browsing this forum: Bing [Bot], ghostryder, trex021 and 39 guests
