Post new topic Reply to topic  [ 9 posts ]
PostPosted: Wed Jul 25, 2012 2:01 pm
So it seems like I'll have a spare front BR 7900.
Until now when I'be been swapping between carbon rims/deep section to alu rim C24's (for windy days) I've just been swapping the shoes. Any beneift to think about swapping out the whole caliper? Seems a bit less fiddly (not having to get them aligned spot on each time), but might cause a lot of cable wear around the pinch bolt.
Assuming I wont have to remove the cable ends and the cable and adjuster barrel can come in and out of the caliper in one peice.
Di2x2
PostPosted: Wed Jul 25, 2012 2:17 pm
Formerly known as PezTech
The cable would be why I wouldn't swap calipers... Shoes are probably easier anyhow.
charles@pezcyclingnews.com
PostPosted: Wed Jul 25, 2012 2:24 pm
Or use these EE Brake Pad Holders http://fairwheelbikes.com/ee-brake-pad- ... -1964.html , if they're ever in stock. Allows you to easily swap pads, presuming a single shoe placement works for both wheels.
PostPosted: Wed Jul 25, 2012 2:30 pm
I'm thinking just swapping the pads would be easiest? In fact I've been pondering to look for knurled-head screws, so the pads can be swapped without the allen key.
Bikes: Raceur, Beateur
PostPosted: Wed Jul 25, 2012 2:34 pm
I had a separate set of pads/holders and swapped them out....you usually need to adjust positioning anyways so seemed like the less fuss solution.
PostPosted: Wed Jul 25, 2012 2:49 pm
I just find it way more fiddly to adjust the toe-in, compared to frobbing the inline cable length adjuster a bit.
PostPosted: Thu Jul 26, 2012 12:43 am
I swap pads. Adjusting the toe-in and pad position takes me 2-3x longer than swapping pads on Shimano style holders with the set screws.
I mark my pads front and rear so they go back in the same position.
PostPosted: Thu Jul 26, 2012 1:54 pm
+1 on shoes. For toe-in, use the same shim every time. Presto.
PostPosted: Thu Jul 26, 2012 3:39 pm
I also swap pads back and forth for my race and training wheels. It takes about 5 minutes to remove one set of wheels, swap pads and install the second set of wheels.
Like eric, I keep my carbon pads (front and rear) separate from my alu pads. I keep the ones not currently on the bike in a baggie marked for front and rear so they go back into the same position each time. A small alignment on my front brake once the wheel is on and i'm ready to go.
I usually clean off each of the pads when removing them so i keep the dust level down and allow the pads to last a little longer. This also gives me a chance to inspect them for hunks of metal or debris.
Users browsing this forum: Bing [Bot], dalex, Google [Bot] and 39 guests
There are no new unread posts for this topic. New Shoes & Pedals vs aero frame/wheels
airwise
21
1161
Sat Jul 14, 2012 12:55 am
reggiebaseball View the latest post
There are no new unread posts for this topic. Swapping chainrings on Fulcrum RS crankset 50/34 > 39/53
parajba
Mon Jul 02, 2012 9:33 am
parajba View the latest post
There are no new unread posts for this topic. Swapping out Campagnolo Athena II for Shimano Ultegra?
Lewis
20
1870
Thu Nov 22, 2012 1:24 pm
Miller View the latest post
There are no new unread posts for this topic. Road Bikes Disk Brakes/Carbon Wheels Dominant Future?
bluhorizan
10
1493
Tue Aug 21, 2012 1:04 am
kulivontot View the latest post
There are no new unread posts for this topic. Possible new brake calipers
mxdclt
10
1256
Tue Oct 16, 2012 3:19 am
dereksmalls View the latest post
It is currently Wed May 22, 2013 6:23 am
