Post new topic Reply to topic  [ 1 post ]
PostPosted: Mon Jul 23, 2012 4:53 am
I was considering ordering an all carbon saddle for my mountain bike, but first I decided to try out the feel of an all carbon saddle by modding one of my old mountain bike saddles first.
The saddle I chose was an old Fizik Aliante with ti rails:
As you can see, the cover was pretty worn and it weighed in at 250 grams.
I proceeded to peel off the leather cover and manually remove the foam padding by hand. This took a while as it was securely glued to the carbon shell. I then broke out the dremel with a soft wire brush to clean the remaining foam off the shell.
The back edges of the saddle were raised about 4 mm to provide a channel for the foam to rest in. I swapped in the sanding drum onto the dremmel and trimmed the edge flat.
Here is a picture post-mod:
As you can see I was able to shave almost 100 grams, but is it rideable?
The proof is in the pudding. I clamped it in place and hit one of our more rocky trails here in Tucson: Starr Pass. I did take along my usual mountain biking saddle (265 g Selle Italia Team) just in case the all carbon saddle was unbearable and I'd need to swap it out.
Amazingly enough, the new no-padding saddle is MORE comfortable than my usual saddle. I can feel the shell flex under me when taking hits while seated. Granted, we do ride with a very high quality chamoise in our team shorts, so padding on a saddle seems a bit redundant. After back to back days riding 12 mile loops on local trails I can now report very little soreness in my arse. Less so than normal. I do ride a hard tail as well.
Drawbacks: It ain't pretty, but I figure it's on a mountain bike so I don't mind my saddle looking a bit beat-up. I suppose I could clear-coat but why bother? The other issue I discovered is that the rear edges of the saddle are a bit sharp when behind the saddle in technical sections. I may blunt them with some foam or rubber if I decide to keep using it.
Cheers,
Ringtail
Users browsing this forum: 604Yarks, EMMANUEL15, Exabot [Bot], Google [Bot], madmartigan, Majestic-12 [Bot] and 43 guests
There are no new unread posts for this topic. Attachment(s) Seat Tuning 101
1spd
11
1732
Wed Jan 16, 2013 1:06 am
odin99 View the latest post
There are no new unread posts for this topic. Attachment(s) Eggbeater tuning
modebo
Wed Jun 06, 2012 12:11 am
modebo View the latest post
There are no new unread posts for this topic. Attachment(s) Show me Your Tuning!
[ Go to page: 1 ... 17, 18, 19 ]
weeracerweenie
282
23371
Sun May 19, 2013 12:45 pm
weeracerweenie View the latest post
There are no new unread posts for this topic. Mavic CCU rear hub tuning... possible?
Dominvs
Wed Oct 03, 2012 3:14 pm
mrfish View the latest post
There are no new unread posts for this topic. Attachment(s) SRAM Red cassette Tuning?
weeracerweenie
27
2819
Sun Sep 23, 2012 9:51 am
It is currently Tue May 21, 2013 7:48 am
