Post new topic Reply to topic  [ 10 posts ]
PostPosted: Fri Jul 20, 2012 12:14 am
I have modified the original expansion plug to extend my steer tube length by ~2cm.
Is there any potential problem with this setup?
With stem
PostPosted: Fri Jul 20, 2012 12:20 am
At least the bottom of your stem will be clamping the steerer tube !
PostPosted: Fri Jul 20, 2012 12:26 am
Location: somewere floating between here and the other side
Isnt your expander going to work as a lever ? If your stem clamps on the ally bit the force on the carbon clambing area is going to be bigger than in a normal situation ?
PostPosted: Fri Jul 20, 2012 6:19 am
Oh god yes
PostPosted: Fri Jul 20, 2012 6:22 am
Depends on how thick the carbon tube is, but for normal road riding probably OK.
Experimental Prototype
PostPosted: Fri Jul 20, 2012 6:35 am
+1
Simply to risky considering the high torsional forces applied to the steer tube...not worth it!
Just curious, where did u find such a gizmo, or is this something you CNC'ed yourself?
EM3
________________
My 2011 Cervelo R5
PostPosted: Fri Jul 20, 2012 8:39 am
The fork is 1" Colnago Star Carbon fork and the tube thickness is ~3 - 3.5mm.
em3 wrote:
+1
EM3
My friend made this one for me with his CNC.
PostPosted: Fri Jul 20, 2012 8:44 am
Cinelli Grammo titanium :beerchug:
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Mon Mar 11, 2013 4:51 pm
side note, that stem has a TON of stack height. perhaps use something with lower profile?
The Chronic
PostPosted: Mon Mar 11, 2013 5:11 pm
Can't really tell whether it's safe or not without knowing the height of the spacer stack below the stem.
It might look shite but can't you just flip the stem?
Users browsing this forum: Bing [Bot], CBRE, Google Adsense [Bot], jdott, rijndael, WMW and 77 guests
There are no new unread posts for this topic. Extending caliper reach?
WeightySteve
11
406
Fri Jul 20, 2012 1:44 am
There are no new unread posts for this topic. Gap inside stem to fork, steerer tube
tri
Wed Sep 26, 2012 10:05 am
ttts2 View the latest post
There are no new unread posts for this topic. Fork Question: 1.125 Steerer in Tapered Head Tube ?
ldamelio
Wed Dec 19, 2012 1:54 pm
btompkins0112 View the latest post
There are no new unread posts for this topic. Thin carbon tube, good or bad?
ichobi
Mon Mar 11, 2013 5:02 pm
ichobi View the latest post
There are no new unread posts for this topic. Drill hole in carbon tube. How?
Zak
10
690
Fri Mar 15, 2013 3:13 pm
natiedean24 View the latest post
It is currently Sun May 19, 2013 10:59 pm
