Post new topic Reply to topic  [ 69 posts ]
Go to page 1, 2, 3, 4, 5  Next
PostPosted: Thu Jul 19, 2012 10:49 pm
Sounds pretty interesting...
http://www.bikerumor.com/2012/07/19/swi ... he-leader/" onclick="window.open(this.href);return false;
PostPosted: Thu Jul 19, 2012 11:11 pm
Any word on a Lightweight (CarbonSports) version of this, or how they are viewed by CarbonSports for use on various Lightweight wheel models? Will there be "no need" for a separate, and allegedly different (well, at least in color and color of residue left on rim) Lightweight=branded version?
I don't see any mention of durability of these pads vs. Yellow Kings, nor of comparison of wear they induce on rims.
PostPosted: Fri Jul 20, 2012 7:58 am
What I don't understand is the heat claim. What a pad should do is cause restistance on the brake surface during braking, this generates stopping power and heat. So to a certain levell more heat means more stopping power.
On the other hand the yellow pads became a bit outdated compared to for example the much cheaper blue Reynolds pads (I use them and they perform way better than both the yellow kings and the black LW swisstops).
PostPosted: Fri Jul 20, 2012 10:02 am
i also wondered about the heat
it seems this is just a single braking event, if the temperature is for the pad surface, it may simply be that the new pads have much better thermal conductivity, so they'll sink more heat into the holders/calipers and reduce the rate of temperature increase
PostPosted: Fri Jul 20, 2012 10:58 am
Before we can give approval for usage of Black Prince pads in combination with Lightweight wheels, we have to do our own tests - both on road and in laboratory.
This will take some weeks. Until that only the Lightweight by Swissstop pads are allowed for Lightweights wheels to avoid a loss of warranty.
Andreas Schiwy, CarbonSports GmbH
http://www.lightweight.info
support[at]lightweight.info
PostPosted: Fri Jul 20, 2012 12:01 pm
Also a question for the lightweight wheels - have you ever tested the Zipp Tangente pads with your wheels. They appear to be the same as yours but are more easily available sometimes.
PostPosted: Fri Jul 20, 2012 12:11 pm
I got to ride them. Very good pads makes carbon feel like alum. Very good heat control and solid braking.
PostPosted: Fri Jul 20, 2012 12:22 pm
I used yellow swisstop on my 404 tubes wheels and they made noise no mater what, I moved to the Zipp Tangerine, no sounds and better stopping performance. I don't know how the Tangerine will works with Lightweight.
PostPosted: Fri Jul 20, 2012 1:26 pm
Hope that its not just a marketing gag because everything goes black so SS "must" follow.
And that they will not higher priced than the already costy yellows.
Like sharkman said the Reynolds blue are performing better than the SS yellow.
PostPosted: Fri Jul 20, 2012 1:54 pm
To balance opinions, in my unscientific tests I found Swiss yellow and Reynolds blue to perform more or less equally well on basalt-enhanced yishun rims. Both are squealing too.
Bikes: Raceur, Beateur
PostPosted: Fri Jul 20, 2012 6:04 pm
The Zipp are not squealing!
PostPosted: Fri Jul 20, 2012 7:04 pm
Formerly known as PezTech
Higher stopping power/ friction doesn't have to equal "more" heat than pads that doesn't stop as well...
Some companies pads wear faster and shed material (without building heat) in the process of stopping better, some have a bit more surface area and some use material that simply doesn't conduct as much while the surface maintains or increases the friction / stopping power.
The better newer pads from a few companies are a combination of these things.
charles@pezcyclingnews.com
PostPosted: Fri Jul 20, 2012 8:51 pm
That might be correct on quality pads compared to really old fashioned stuff or pads that aren't up to the job between good pads there als only marginal differences (so more stopping power has to come with raised friction and more heat).
I think what Carbonsports is trying to tell is that if the Swisstop claim is viable (more stopping power with cooler pads) the heat has to dissapear through the holder/brakes and rim and testing is the only way to see if the claimed better performance doesn't come at a price.
PostPosted: Fri Jul 20, 2012 10:09 pm
I've used a lot of different pads on my reynolds dv46s including swisstop yellow and none of them come close to these black zipp pads, anyone have the same experience? I noticed on the website they say to use them with aluminum clincher rims, but they seem to work just fine on carbon.
PostPosted: Sat Jul 21, 2012 4:26 pm
Yes...
The yellows were good relative to other pads but different compounds in the last couple of years came into play that could both brake better and, yes, create less heat at the rim (and not melt and lay a coating onto the rim, which the yellows would do under fairly extreme conditions)
Carbon sports is no different than every other quality rim maker looking for (and finding) that compound / material selections have improved.
Different rim makers have different concenrs though and it's down to rim construction difs. Zipp did a better job with resin and their rim simply doesn't heat up as much as many others, but the surface has a different texture than many. A few other rim makers are using coatings... Some are just looking for better pad compounds. All are finding better solutions but it's not a "one pad for all" solution...
Post new topic Reply to topic  [ 69 posts ]  Go to page 1, 2, 3, 4, 5  Next
Users browsing this forum: Exabot [Bot], tommasini and 58 guests
There are no new unread posts for this topic. Are these SwissStop green pads?
blantonator
Thu Aug 09, 2012 11:47 am
franco78_fr View the latest post
There are no new unread posts for this topic. Swissstop BXP 2013 Pads
lactatehate
16
1349
Fri May 17, 2013 12:02 pm
BdaGhisallo View the latest post
There are no new unread posts for this topic. OBE Carbon rim pads
chazzawoods
Thu Sep 06, 2012 10:51 pm
eric View the latest post
There are no new unread posts for this topic. Best modulating brake pads for carbon wheels?
drmutley
27
1330
Mon Apr 08, 2013 9:31 pm
danielbahia View the latest post
There are no new unread posts for this topic. Best Brake Pads for Zipp 303 carbon tubular wheelset
bluhorizan
16
1359
Wed Dec 05, 2012 6:31 am
tetonrider View the latest post
It is currently Fri May 24, 2013 6:09 am
Swissstop brake pades & Swissstop disc brake pads - starbike.com
