Post new topic Reply to topic  [ 12 posts ]
 Post subject: Extending caliper reach?
PostPosted: Thu Jul 19, 2012 8:39 pm
Any suggestions for getting about 2mm extra reach from my front DA 7900 calipers?
I am loathed to have to replace them for a BR650 (57mm drop), just for the sake of 2mm, but can't find a way out.
I tried flipping the DA pads around L/R because they kinda point upwards when normally installed, but this didnt really work (top of pad just off the rim, not on the tyre, but with a bit of wear it would be). Theoretically I could attempt to dremel/drill out 2mm from the fork dropouts but that's a bit scary!
Maybe a different shoe would give me just that extra bit of drop?
Di2x2
PostPosted: Thu Jul 19, 2012 8:55 pm
How about drilling 2mm from the caliper pad holder holes?
PostPosted: Thu Jul 19, 2012 8:56 pm
PostPosted: Thu Jul 19, 2012 8:57 pm
They only have about 3mm from hole to bottom edge.
Di2x2
PostPosted: Thu Jul 19, 2012 9:08 pm
Now something like this would work...
http://www.imperialsupplies.com/item/0765320" onclick="window.open(this.href);return false;
I can angle the bolt downwards with this get just about a 2mm drop, then use the toe-in on the shoe to level it up with the rim. Now to find them in the uk...
Edit: Turns out they are not so difficult to make with an inner tube nut and a dremel :)
Di2x2
PostPosted: Thu Jul 19, 2012 11:35 pm
So after about 90 mins dremelling, fitting those brake a shoes just simply refuse to toe in at such an angle, and so a. BR 650 now looks like the only realistic solution.
Di2x2
PostPosted: Fri Jul 20, 2012 12:14 am
Drop bolt?
http://sheldonbrown.com/dpdropbolt.html" onclick="window.open(this.href);return false;
No. Forget I mentioned it. :oops:
r o y g b i v
PostPosted: Fri Jul 20, 2012 12:29 am
You can try something that worked for me when converting a frame designed for 27 inch wheels to 700c.
All I did was shave 2mm from the top edge of the brake pad where it would contact the rim. Leave the part inside the shoe holder intact.
You probably won't even notice the decrease in braking force due to the decrease in contact area.
PostPosted: Fri Jul 20, 2012 12:34 am
Seems there no one selling them anymore, and not sure how they perform A specially designed shoe would be perfect, but doesnt look like they exist.
http://www.bentrideronline.com/messageb ... hp?t=54096" onclick="window.open(this.href);return false;
sums it up pretty nicely.
Di2x2
PostPosted: Fri Jul 20, 2012 12:36 am
2mm off a 7900 pad would be nearly half of it.
Di2x2
PostPosted: Fri Jul 20, 2012 12:53 am
The pads I have (Blue Reynolds) are 7.5 mm wide, so 2 mm is less than a third, closer to a fourth.
Older pads (like from sidepulls) are about 11 mm so 2 mm from that would be negligible indeed.
PostPosted: Fri Jul 20, 2012 1:44 am
this is what you need but it looks like theyre not around anymore. im still looking.
Users browsing this forum: Bing [Bot], carbon2329, CarpetFibre, cyclistcong, deek, Exabot [Bot], VMac and 82 guests
There are no new unread posts for this topic. Attachment(s) Extending carbon fork steer tube
xFree
9
743
Mon Mar 11, 2013 5:11 pm
Svetty View the latest post
There are no new unread posts for this topic. lightest disc caliper
cymans
11
2029
Fri Jul 20, 2012 3:06 pm
bones View the latest post
There are no new unread posts for this topic. DA rear caliper on the front?
wassertreter
Sat Sep 08, 2012 4:53 am
oysters View the latest post
There are no new unread posts for this topic. Strange noise in front brake caliper/cable
Burning Dogma
Sat May 26, 2012 6:27 pm
madmole View the latest post
There are no new unread posts for this topic. Attachment(s) Convert a shimano front brake caliper to a rear?
dmoneysworks
Mon Feb 18, 2013 1:18 am
ms6073 View the latest post
It is currently Wed May 22, 2013 4:58 pm
