Post new topic Reply to topic  [ 22 posts ]
Go to page 1, 2  Next
PostPosted: Thu Jul 19, 2012 6:32 am
I am building a BMC IMPEC (all Campagnolo). I have a Colnago M10 Super Record 11s with the Rear Dual Pivot brake option, and I am debating using the standard (single) Super Record Rear Brake on my IMPEC. I have had very good results on the M10 - great brakes - but assume the standard rear is typical great Campagnolo and should save me some weight and look kinda cool on the bike.
I do know the single is a bit tougher to center because its not a solid once mounted on the bike (has some wiggle) - but it's the rear and I have similar issues with my THM Fibula and once set well they work fine.
Any thoughts?
JW
PostPosted: Thu Jul 19, 2012 11:34 am
Minor decision, but I'd go with whatever stays centred the best. Rear braking power above a certain point (i.e. enough to help out spreading the heat on long mountain descents) is a non-issue.
PostPosted: Thu Jul 19, 2012 11:43 am
The single pivot gets props for modulation and its a tiny bit lighter. Of course if they were the only criteria you'd get an EE.
r o y g b i v
PostPosted: Thu Jul 19, 2012 12:43 pm
I've always preferred the single pivot because you really don't need as much braking power on the back with the forward weight bias of a bike, particularly in a hard stop.
PostPosted: Thu Jul 19, 2012 1:15 pm
I went single pivot on the rear, a bit lighter, more than enough stopping power, just as easy to centre and doesn't look as clunky
Pegoretti Responsorium
Parlee Z5i
Donhou Commuter
PostPosted: Thu Jul 19, 2012 1:47 pm
My vote goes to the dual pivot. When Campagnolo went to the single pivot it saved a bit of weight and the marketers decided that in lieu of hyping sheer braking power they would hype the "better modulation" aspect. I was using their dual pivots before that, then used the single pivot again until they came out with the dual pivot once again. Despite the marketing line, I feel that modulation is better with the dual pivot. Why? Because it simply operates more smoothly and evenly. Modulation comes primarily from the rider and the smoothness of brake operation. The dual pivot is easier to, and stays centered better than the single pivot as well. And it is buttery smooth in operation. These things are more important to me than a few grams.
My Colnago C59
My Special Colnago EPQ
PostPosted: Thu Jul 19, 2012 2:47 pm
I just installed the single. Have both sets - removed the dual from my CA to install the Fibula. The single does wiggle - one spring - but I think it should center ok. The dual is locked and never moves which is nice - but I like the look of the different brake in the back. Brake is "prettier". Has anyone done or seen 2 singles. That would have been a cool option for my lightweight CA instead of the Fibula maybe.
PostPosted: Thu Jul 19, 2012 2:52 pm
They both work fine so can't fault your decision. "Pretty" counts. I understand.
My Colnago C59
PostPosted: Thu Jul 19, 2012 2:57 pm
if you keep your kit for a short while or hardly use it, single pivot
But if like me when some new latest groupset comes along you buy install on your best bike, then move that older hardware down the bikes over years I've found the dual pivot just keep on working. record ones from 2004 or 2005 on my old winter bike work like new
Parlee Z1 Gloss SR11 LW Obi
Parlee Z1 Nude SR11 Hyperon
Parlee Z5 SR11 (for sale)
Enigma Etape Ti SR11 +rack
Teschner TT - LW12spoke/LW Disc
Pinarello Opera 90's steel Rec10
PostPosted: Thu Jul 19, 2012 4:48 pm
I prefer the aesthetics of the single pivot, and do find it less likely to lock up in panic stops. I think this is a big plus.
The dual pivot is easy to center by hand in a pinch, just wiggle it.
While the single pivot is a bit trickier to set up the first time, but seems to stay put after that.
Either will be great. I think you should get the single pivot just so you have first hand experience with both - it will not impact your riding experience much.
PostPosted: Thu Jul 19, 2012 8:40 pm
220lbs using single pivot on the back and naver an issue with braking or centering, great breaks that just keep on working year after year.
PostPosted: Fri Jul 20, 2012 11:46 am
Thanks all. Single is on for now and bike should be finished next week.
PostPosted: Sat Jul 21, 2012 1:15 am
I have a single on the back;Campy say's it avoids lock up, and their right.
PostPosted: Sat Jul 21, 2012 4:34 am
+1 on single pivot. Modulation is good enough, and power a non-issue.
PostPosted: Sat Jul 21, 2012 4:44 am
Single Pivot, great modulation and more then enough power. Easy set up and when centered correctly (using a flat wrench, old school method) will permanently stay centered.
EM3
________________
My 2011 Cervelo R5
Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], Google [Bot], Google Adsense [Bot], HammerTime2, KLabs, sanrensho, VMac, wrcompositi and 47 guests
There are no new unread posts for this topic. dual-pivot light brakes?
inertianinja
Mon Jul 23, 2012 6:29 pm
Arky View the latest post
There are no new unread posts for this topic. Super Record D Skeleton Brakes
coolmingli
Sat Apr 27, 2013 6:09 pm
Valbrona View the latest post
There are no new unread posts for this topic. Super Record 11 Rear Mech Failure - any others out there ?
lycralout
21
1548
Mon Sep 24, 2012 5:11 pm
Powerful Pete View the latest post
There are no new unread posts for this topic. FSA K Force Light Wilier BB386Evo vs Campy Super Record Crnk
Berlingtonberty
Fri Nov 30, 2012 5:50 pm
Briscoelab View the latest post
This topic is locked, you cannot edit posts or make further replies. 2010 super record 11 vs 2012 super record 11
Rumshcawheely
Sun Feb 24, 2013 2:21 am
milroy View the latest post
It is currently Wed Jun 19, 2013 1:22 am
