Post new topic Reply to topic  [ 32 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Wed Jul 18, 2012 12:43 pm
Excuse me, YAWD stands for? :noidea:
PostPosted: Wed Jul 18, 2012 3:37 pm
Formerly known as PezTech
It means the front mech changes angle as you go from big to smal to big rings...
Old ones stay straight front to back where new ones both rise up (going to big) and actually angle a little to match the chain line virtually eliminating chain rub when crossed over.
charles@pezcyclingnews.com
PostPosted: Wed Jul 18, 2012 4:11 pm
http://en.wikipedia.org/wiki/Yaw_(rotation)
Exp001
PostPosted: Wed Jul 18, 2012 4:33 pm
Now it's all clear. Thank you very much! :beerchug:
PostPosted: Fri Jul 20, 2012 5:53 am
Are the Hi/Lo limit screws M4 or M3 ?
My calipers are reading 3.5mm :?
I would think that they would make the hi/lo limit screws interchangable with the RD's hi/lo screws which are M4
Exp001
PostPosted: Fri Jul 20, 2012 6:21 am
So I took care of the FD installation today. Thanks timzcat.
I pretty much followed this video: http://www.youtube.com/watch?v=UEb8qjWILnY
It was pretty easy and the result is pretty incredible. Just as everyone says. I am using 2011 old red shifters. I literally took the old one off and just put the new one on with the same used cable. It feels like my life has changed with this derailleur. I might be exaggerating, but it really is better than anything I have ever tried.
Cervélo S2 2012 Red
Great minds think alike... sadly, so do the mediocre ones.
PostPosted: Fri Jul 20, 2012 7:03 am
@cervelobert: can you post some pictures? Does the Yaw look good with the "old" Red parts?
Specialized Tarmac S-works SL4
http://i891.photobucket.com/albums/ac11 ... 11af34.jpg
PostPosted: Fri Jul 20, 2012 4:20 pm
I only took one picture after the installation. It has a chrome finish and it is obviously newer than all the parts. I'm sure as things get dirtier, it will all start to look more uniform again, but it looks fine to me. Imagine this on a Cervelo S2 with a 2011 Red Group. Chain catcher is great, but I forgot to weigh all the parts before installing due to my excitement.
File comment: I wish I could dip my balls in it.
Cervélo S2 2012 Red
PostPosted: Fri Jul 20, 2012 4:59 pm
Great..thanks for the picture. Did you use the cable tension barrel adjuster?
PostPosted: Fri Jul 20, 2012 6:36 pm
Nope, just a straight on, and forgot about it. I think next time I change out my cables I'm going to put the adjuster in, but... why?
Cervélo S2 2012 Red
PostPosted: Fri Jul 20, 2012 8:08 pm
I was wondering if I needed the barrel adjuster that comes with the yaw FD.
PostPosted: Fri Jul 20, 2012 8:47 pm
It's going to make fine tuning very easy. I would use it versus a bunch of fiddling with trying to perfectly tension the cable.
PostPosted: Fri Jul 20, 2012 11:25 pm
CharlesM is right I guess. Like I said, I was just so excited I even forgot to weigh it.
Cervélo S2 2012 Red
PostPosted: Sat Jul 21, 2012 11:33 pm
Last week I set up the new Yaw FD with new Red Clamp Adapter with the following:
Old Red Shifters
Force Compact Cranks
Rotor Q-Rings 50/34
Force RD
KMC Ti-SL Gold Chain
On my PedalForce CG1
Prior to the change I was having trouble dropping the chain OVER the big ring using the 1091R Chain. Reading the WW forums, I decided it was better to swap the SRAM chain for the slightly wider KMC Chain.
I'd never completely set up a FD before (always leaving the adjustment to my LBS), and this was pretty easy to do after I got the height correct.
In practice, it works a hell of a lot better than my Force FD did. Shifts are confident, solid, and very accurate.
PostPosted: Sun Jul 22, 2012 12:31 am
CharlesM wrote:
Guy's I'm not guessing at this or asking SRAM... I have a new front mech on an old group set and it just plain works better.
I think Velonews covered most of the combinations and they also found that putting the 2012 Front der on the old SRAM group simply works quite a bit better.
The steel cage Force is a slight improvement, The 2012 RED is a substantial one, but I wouldnt change from the steel just to change... Frankly, any bitching about the steel one is mostly hot air. It works well. The Ti ones worked OK, but when you get the new one it's simply bang on.
That said, the entire new 2012 group is not only a breeze to set up, the whole thing works extremely well.
^all of this.
I'm not sure why you'd change the FD if admittedly you're not unhappy with your current steel cage.
I'm also not sure why you'd start another thread because because you didn't like the answers in the previous/current thread about the same topic.
Post new topic Reply to topic  [ 32 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: No registered users and 49 guests
There are no new unread posts for this topic. SRAM chainring and front derailleur problems
bluhorizan
Fri Aug 17, 2012 7:57 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Sram Red front derailleur(non yaw) with Chorus 10 speed shif
digiadaamore
Wed May 15, 2013 10:19 pm
dereksmalls View the latest post
There are no new unread posts for this topic. BTP front derailleur
kevosinn
Wed Sep 19, 2012 2:14 am
kevosinn View the latest post
There are no new unread posts for this topic. Is this the end of the front derailleur?
SWijland
23
2015
Sun Dec 23, 2012 2:05 pm
Franklin View the latest post
There are no new unread posts for this topic. Front derailleur problem
wally318
Mon Apr 15, 2013 4:59 pm
sigismond0 View the latest post
It is currently Fri May 24, 2013 6:23 am
SRAM Red front derailleur
