Post new topic Reply to topic  [ 5 posts ]
PostPosted: Mon Jul 16, 2012 12:46 pm
A discussion at Superweek yesterday and this question was posed!
Wheel A is 58mm deep and weights 1450 grams
Wheel B is 38mm deep and also weight 1450 grams.
Is rotational weight the same or is it easier to spin up the shallower wheel due to cutting through the wind on acceleration?
Does it make no difference as to depth if their the same weight?
It almost seems like its hard to start a sprint or acceleration on deeper wheels of the same weigh!
PostPosted: Mon Jul 16, 2012 12:58 pm
I would've thought that the deeper wheel is easier to spin since less of the weight is on the outer edge (hence less force required to rotate it). However, since the weight distribution is so small (12mm) the extra depth might be causing a drag effect that overpowers the beneficial effect from having the weight closer to the hub.
PostPosted: Mon Jul 16, 2012 1:02 pm
Not enough information to do the calculation, you need to know where the mass is. Imagine one wheel having internal nipples, then the spoke bed would be farther out, meaning more inertia.
Not that I think it would make a difference in real world.
Bikes: Raceur, Beateur
PostPosted: Mon Jul 16, 2012 1:35 pm
Rollers are the best way for someone to see for themselves how much impact wheel inertia is having on there accelerations. Try out a few different wheels using the same protocol, and then the next time wheel inertia comes up you'll find yourself doing :roll:
PostPosted: Tue Jul 17, 2012 2:35 am
It's likely that the deeper wheel will have a lower moment of inertia. Wassertreter is 100% correct though. Not enough info.
However, the difference in practice would be so small and the aero advantage with a deeper set would be greater that the better choice really is the deeper set. All things considered, unless a shallower set is significantly lighter, aero is better.
BMC SLC01
Visiting South West Australia? Visit Crank n' Cycles!
Users browsing this forum: Bing [Bot], CBJ, Exabot [Bot], normcorriveau and 33 guests
There are no new unread posts for this topic. recommend me a <$20 scale for weighing parts
odin99
Sun Mar 03, 2013 4:05 am
vwo05 View the latest post
There are no new unread posts for this topic. What carbon wheel depth combination?!
Guyeclipse
13
1039
Mon Dec 03, 2012 4:13 am
Johnny Rad View the latest post
There are no new unread posts for this topic. 3D rotor crank - any diff?
project3
9
824
Mon Jan 07, 2013 3:05 am
NiFTY View the latest post
There are no new unread posts for this topic. Help calculating saddle position between two bikes with diff
Ufgators
Thu Oct 18, 2012 7:53 pm
kulivontot View the latest post
There are no new unread posts for this topic. Attachment(s) spot the diff between these 2 deda 35mm stem
project3
13
1341
Sun Sep 30, 2012 8:32 pm
artray View the latest post
It is currently Sat May 25, 2013 2:33 am
