Post new topic Reply to topic  [ 21 posts ]
Go to page Previous  1, 2
PostPosted: Mon Jul 16, 2012 12:26 pm
Just as I suspected. That guy doesn't really know what BB30 is. BB30 and BSA have the same width shell 68mm. It's good that he will take them back but you are wasting your time.
BB30 Technical drawing from Cannondale
PostPosted: Sat Jan 12, 2013 5:40 am
The btm bracket in question can be used with ZIPP Vuma Quads.
PostPosted: Sun Jan 13, 2013 4:11 pm
Yes, but that is because the Vumaquad crank has a longer spindle - sort of a precursor to BBRight/EVO386 - than cranksets that were manufactured to conform to the BB30 standard.
PostPosted: Sun Jan 13, 2013 4:17 pm
There's a number of companies that use the same BB cups. Lightning, Rotor are a couple. They use the same bearings as BB30- 6803- with a 30mm ID. But since they are outboard of the BSA shell, the width is greater than true BB30. Some "BB30" cranks have a long enough spindle so that they'll fit. But then they don't have the nice heel clearance of a real BB30 crank.
PostPosted: Sun Jan 13, 2013 10:01 pm
I'm fully aware of that. Thus my post.
I wasn't saying the ZIPP is a BB30 crank. It has a 30mm spindle, that's where the similarity ends.
PostPosted: Sun Jan 13, 2013 10:20 pm
When looking at the Bdop Cycling web site there is quite a bit of info describing that a long spindle is needed to use that btm brkt.
Quote:
Each cup adds roughly 10mm in width which means your crank axle must be at least 88mm long > 68mm +10mm+10mm=88mm.
I suppose that info wasn't there when the O.P. was making his initial hunt.
Seems like some of the "purists" here, (and maybe I'm one of them) is getting hung up about the true definition of a BB30 crank set. I ride Cannondale and BB30. I tend to believe that to use that label your crank set better be able to fit in the traditional (68)mm OR (73)mm wide MTB shell. If you're crank spindle is so long that it uses outboard bearings then I consider it incorrect to call the crank set a BB30 crank.
So if your bike has a shell that is; BB30 / PF30 / Specialized 2013 OSB with NO outboard bearings, call it BB30.
The term has been bastardized by so many vendors who want to use the term.
Speaking of Specialized, what's up with them for 2013? The tech in my LBS said the shell in the 2013 Tarmac is slightly different than the normal PF30 inside diam. He said it was changed to a standard inside diameter dimension that is NOT PF30.
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], FastTarik, Google [Bot], oreoboreo and 31 guests
There are no new unread posts for this topic. Installing Campy BB30 UT Cups
JWolf
13
649
Thu Aug 02, 2012 8:27 am
dierix View the latest post
There are no new unread posts for this topic. BB30 Frame or not with Shimano cranks?
Rideuphill
7
848
Sat Aug 11, 2012 10:31 am
chazzawoods View the latest post
There are no new unread posts for this topic. Need help with a threaded headset.
JWolf
Tue Aug 28, 2012 5:58 am
JWolf View the latest post
There are no new unread posts for this topic. 36T threaded chainring for Campy SR
roadwarrior
Wed Dec 12, 2012 7:31 am
roadwarrior View the latest post
There are no new unread posts for this topic. Best value carbon crankset for 68mm threaded BB?
Porschenut
10
885
Fri Jun 15, 2012 1:33 am
Porschenut View the latest post
It is currently Sat May 25, 2013 1:18 am
