Post new topic Reply to topic  [ 21 posts ]
Go to page 1, 2  Next
PostPosted: Sat Jul 14, 2012 6:47 pm
I've done a pretty extensive search to find a way to use use a BB30 crankset in my BMC Racemaster, so the reason for the post is I found this... (towards the bottom of the page, (T30)
http://www.bdopcycling.com/First-Bottom%20Brackets.asp" onclick="window.open(this.href);return false;
Does this actually mean I can use a SRAM Red BB30 crankset in my frame? If so, this means I can drop a ton of weight and improve shifting going to the NEW RED on my Racemaster.
PostPosted: Sat Jul 14, 2012 7:01 pm
No. sorry.
PostPosted: Sat Jul 14, 2012 7:35 pm
Since the overall width of a BB30 BB is 68mm including the bearings, and the BB30 crank spindles are made to work with that, I don't understand how those external cups would work. The spindle will be much too short, no? What am I missing?
dangerous curves ahead
PostPosted: Sat Jul 14, 2012 7:45 pm
You should be able to use a Sram S900, Rotor 3D+, or the newer BB386 cranks with those BSA to BB30 adapters as these cranks have wider spindles. Someone here has successfully used the Sram S900 cranks. You cannot make it work with Red, Force, or other 'standard' BB30 cranks. There are some other threads discussing this same topic.
PostPosted: Sat Jul 14, 2012 9:23 pm
That was my understanding too. So, their description "The T30 allows you to use your BB30 cranks on a standard BSA Frame. " is somewhat misleading? Are they not disclosing that you can use a BB30 crank IF you have a longer spindle?
Their descriptions makes it sound like you can use a standard BB30 crank (ie. RED, FORCE) on a 68mm BSA frame. I understand that the Rotor 3D+ and "386" cranks have a longer spindle.
PostPosted: Sun Jul 15, 2012 12:15 am
Certain crank manufacturers call their cranks BB30 when they are not. They are just standard cranks with 30mm spindles. There is more to BB30 than just the 30 mm spindle, so yes it is misleading. Basically imo they want to jump on the BB30 bandwagon without having to invest the capitol to build a BB30 crank, so they accomplish this by slapping on a 30mm spindle and pass it off as the Real McCoy to less savvy customers.
Sorry about the rant but I think it's really confusing, unnecessary, and misleading to market a crank as BB30 just because it can fit in a BB30 BB shell...what crank can't?
As far as those cups go who knows :noidea: maybe the seller or manufacturere doesn't know any better.
PostPosted: Sun Jul 15, 2012 3:39 am
I ended up emailing this topic this morning and got a response by the afternoon.
ME- Hello,
I just wanted to confirm that it is my understanding that I can use
my traditional 68mm threaded road frame (BMC racemaster) and install a
SRAM Red BB30 crankset using your T30 BB?
Them-Thanks for the email.
You are correct. That is the exact type of application the T30 was designed for: BSA to BB30.
We ship internationally every day. Just click on the PayPal button and you're good to go. FYI, we now have Italian threaded versions but haven't updated our website.
Regards,
Timothy Barkley
BDop Cycling Company Ltd.
www.bdopcycling.com
Sales:sales@bdopcycling.com
Sourcing:timothy@bdopcycling.com
Facebook: BDop Cycling Company
Tel: +886 6 2629706
Fax:+886 6 262 2183
PostPosted: Sun Jul 15, 2012 4:59 am
All I'll say is that one of us is right and one of us is wrong. Buy that BB and you'll see. If nothing else do yourself a favor before you buy it and, ask if they'll cover the return shipping costs when you have to return it, because it's not compatible with your crank.
PostPosted: Sun Jul 15, 2012 5:59 am
Haven't bought anything yet. No cranks, no BB. Just going through the searches. Everything I have found means it won't work....just thought it was an interesting find.
Not trying to re-hash a debate that's been on here a number of times or tell anyone her they are wrong on this subject, not the reason for the post.
PostPosted: Sun Jul 15, 2012 10:18 am
there is many manifactures that make that sorts of cups, but it´s the same with them al, can´t be used with a "real" bb30 road axle.
PostPosted: Sun Jul 15, 2012 10:27 am
If it was an EVO386 crankset adapter for BSA frameset, then theoretically it might work. But a BB30 ? Not possible as the axle would be too short to accommodate the external bearings.
PostPosted: Sun Jul 15, 2012 10:37 am
Here is the math: the BSA BB shell ID is 35 mm, Italian is 36 mm. The BB30 axle is - of course - 30 mm. In 5-6 mm you have to fit the bearing and some kind of interface with the threaded shell. The minimum thickness of the latter is 1.5 mm, so you have 3.5-4.5 mm left for the bearings. Needle type bearings might be found in this size, but they will not deal with the side load, so at least 1 ball bearing cartridge/side must be used. There is no standard ball bearing cartridge with these measurement parameters in any manufacturers catalog (30X37 is the closest).
PostPosted: Sun Jul 15, 2012 10:56 am
If you're interested in using a powermeter the NEW RED Quarq BB30 crank will work with these cups in your BSA 68mm frame. It is similar in contruction to the S975 but uses the new graphics and chainrings (and quarq). The reason it works is that instead of preloading the bearings with a wavy washer (standard red/force) there is a threaded collar and sleeve. This takes up more room, when removed you have room for the external bb30 cups...just use a wavy washer to preload the bearings.
Grover's Grumblings
Grover's Garage
PostPosted: Mon Jul 16, 2012 5:38 am
I think I will try it based on the fact that I can send it back as a warranty claim and they will cover the cost. Worth the try???
Timothy,
Thanks for the reply. Im a little confused. It had always been my understanding a BB30 crank (Red, Force,FSA) could not be adapted to BSA because of the spindle length is too short with the external cups.
However, with the added spindle length on cranks like Rotor 3d+ and BB386 cranks, they can use a BSA BB.
I want to use a SRAM Red bb30 crank. Just trying to clear up my confusion.
The shell on a BB30 bike is wider than BSA. The cups make up the difference.
I've never installed that exact combination with my own hands but this is the application they were designed for based on factory specs.
We would cover these as a warranty return if there was an issue.
PostPosted: Mon Jul 16, 2012 6:09 am
I´m doing BB30 conversion as part of my living in my shop so I know a bit about that.
A standard BB30 crankset like RED and others have a too narrow axle to fit a BSA threaded frame + two cups, there´s just not enough place.
The best solution is a modular crankset like Lightning which have spacers on the axle, or a MTB version of Sworks cranks on a road frame, they are wider.
I use Cannondale Hollowgram just because they are modular and no way a BSA 68 shell with cups will be at right width for a Hollowgram axle of 104mm, we are talking about use a 131mm axle, a SRM axle at 122 can MAY be used,a 128mm can be used, haven´t tested yet.
Take a look of my attached file.
Experimental Prototype
Post new topic Reply to topic  [ 21 posts ]  Go to page 1, 2  Next
Users browsing this forum: Bing [Bot], Exabot [Bot], Google Adsense [Bot], thatdkid and 69 guests
There are no new unread posts for this topic. Installing Campy BB30 UT Cups
JWolf
13
644
Thu Aug 02, 2012 8:27 am
dierix View the latest post
There are no new unread posts for this topic. THM Clavicula cranks and BB30 Frame.
UKpaul
Wed May 23, 2012 3:07 pm
sugarkane View the latest post
There are no new unread posts for this topic. BB30 Frame or not with Shimano cranks?
Rideuphill
7
844
Sat Aug 11, 2012 10:31 am
chazzawoods View the latest post
There are no new unread posts for this topic. Need help with a threaded headset.
JWolf
Tue Aug 28, 2012 5:58 am
JWolf View the latest post
There are no new unread posts for this topic. 36T threaded chainring for Campy SR
roadwarrior
Wed Dec 12, 2012 7:31 am
roadwarrior View the latest post
It is currently Mon May 20, 2013 3:42 am
