Post new topic Reply to topic  [ 6 posts ]
PostPosted: Sat Jul 14, 2012 5:44 pm
Administrator
The title says it all. My 6.5 year old RXS right pedal died. It was a lock in bar on the front that broke and I'm exploring options.
PostPosted: Sat Jul 14, 2012 7:01 pm
Per http://speedplay.com/index.cfm?fuseacti ... ompareroad , RXS has stack height of 12.5 mm. i-clic is not listed there (way to compare your current products to your competitors' old products, Speedplay).
Per http://velonews.competitor.com/2010/06/ ... als_120504 and other sources, i-clic has stack height of 13 mm, although I'm not clear whether that is an actual difference from RXS, or is just a rounding of 12.5 mm to 13 mm.
http://www.time-sport.com/pedales/time-iclic_11.aspx and http://www.time-sport.com/pedales/time-rxs_14.aspx do not list stack heights.
Contact form (in French) for Time: http://www.time-sport.com/time-france/contact.aspx . timesportusa.com "is not currently available", whatever that means.
In any event, it appears that i-clic is either half a millimeter more or the same stack height as RXS.
PostPosted: Sat Jul 14, 2012 8:09 pm
The info I've got confirms the RXS stack is 12.5 and i-clic 13.0.
PostPosted: Sat Jul 14, 2012 9:33 pm
Plenty of stores still sell RXS pedals. Time themselves still produce the entry level models but there are quite a few high-end models still available.
PostPosted: Sat Jul 14, 2012 10:26 pm
Tubbie Guru
Hi,
That particular part is common to the entire RXS range so I assume Time can still fix it should you want to.
Ciao, ;)
PostPosted: Sun Jul 15, 2012 1:13 am
Administrator
I'll look into that. It I did order a pair of the I-Clic's titanium for only $199 for a pair. Sending them to Time will take a while or even if I can just order the part. I do love the RXS's.
Users browsing this forum: Bing [Bot], CarpetFibre, Google [Bot], headwind816, rijndael, thprice and 42 guests
There are no new unread posts for this topic. stack height on pedals
chippan
Thu Jul 19, 2012 5:51 am
Brandonnie View the latest post
There are no new unread posts for this topic. Shoe stack height comparison?
SolidSnake03
Thu Feb 14, 2013 3:36 am
SolidSnake03 View the latest post
There are no new unread posts for this topic. Attachment(s) Time xpresso pedals
[ Go to page: 1 ... 5, 6, 7 ]
ninjanoir78
99
8642
Fri Apr 26, 2013 12:33 pm
JKolmo View the latest post
There are no new unread posts for this topic. Attachment(s) Time Xpresso 12 Titan Carbon pedals
DavidSantela
37
6062
Thu Jan 03, 2013 10:53 pm
cerro View the latest post
There are no new unread posts for this topic. tarmac sl3 stack and reach
alui
Tue Jan 01, 2013 12:57 pm
BobSantini View the latest post
It is currently Sat May 25, 2013 1:50 pm
