Post new topic Reply to topic  [ 44 posts ]
Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jul 12, 2012 7:28 pm
Full ultegra group on ribble is a hair under $800.
Full carbon chorus 11sp is ~$1100 skip on the brakes and you're in budget.
Full sram force is $840.
PostPosted: Thu Jul 12, 2012 7:31 pm
Force is lighter than Ultegra.
This is Weight Weenies. :smartass:
Exp001
PostPosted: Thu Jul 12, 2012 7:41 pm
transamman1999 wrote:
wow, lots of Sram fans here eh?
It hasn't got anything to do with being a Sram fan or not. When you ask for opinions on a gruppo + pedals for $1000 people tend to come up with ideas based on value, and the value is in the shifters more than anything else. It's sad to say but $1000 just doesn't get you to high up the latter with groupsets nowadays(not that the entry level stuff is bad in anyway), but if your creative you could get a lot more value for your money than simply buying a new ultegra, or Force group.
Off the top of my head I can't see how you could get into even a used Chorus group all in with fresh chain/cables, and a reasonably newish casette + pedals + make your rear wheel compatible for $1000. Would be cool to see if someone can. OP what kind of wheels do you already have?
PostPosted: Thu Jul 12, 2012 8:04 pm
I'd definitely do a used Red/Force mash up. Sram offers great performance and weight for the $$
Trek 5500 - 13.75lbs on a $1400 Budget
20 gram 1x10 chain guide
PostPosted: Thu Jul 12, 2012 9:13 pm
wow, lots of Sram fans here eh? I've only ever ridden with Shimano components but def wouldn't mind trying out anything Sram. Is parted out Sram gear generally cheaper than Shimano, or are just not many ppl here fans of Shimano?.
Shimano is good stuff. A lot of people aren't all that fond of 7900 though.
SRAM is lighter, and cheaper, and they just released a new red groupset. As such, there's a lot of older red being cleared out, so the prices are great. If you are on a budget, its hard to beat the SRAM offerings IMO, especially since you can pickup the old red bits that make a big difference cheap at the moment.
Also, rival derailleurs perform as well or better than the old SRAM red, and are damned cheap for what they are. They also are black, which you asked for ;)
Wow, amazing post, answered many if not all of my questions and then some!! Thank you!
All of my wheelsets have Shimano/Sram compatible hubs.
PostPosted: Thu Jul 12, 2012 10:37 pm
Personally I can't stand SRAM's double tap shifters but that a personal prefernce. I like Shimano soley for the wheel choice and shifting slickness but still (and do) only use Campagnolo. My choice for your budget would Centaur carbon. The three reasons why I like Campag are;
1) the shifters are pleasure to use, a paddle for the upshift, a lever button for the downshift and brake lever that is only that, all positioned in a ideal way.
2) left shifter is not fully indexed like SRAM or shimano allowing you to trim the FD position to avoid all chain rub even when cross chaining, which I don't do anyway so kind of pointless but I like it none the less.
3) Campagnolo kit is so much more pretty- persopnal preference though.
From a weight wennies point of view I think Centaur carbon might be like than 105 as well. For pedals Shimano makle the best for the price so I would use those.
www.thecycleclinic.co.uk
PostPosted: Thu Jul 12, 2012 10:41 pm
I'd try grabbin a used 10 or 11sp Campy Chorus gruppo/Speedplay X2 pedals.
TA
PostPosted: Thu Jul 12, 2012 10:43 pm
SRAM Red levers allow for trim.
Can be found used on the cheap, perfect working order.
And they're lighter.
SRAM Red levers also have both adjustable reach.
I understand that you personally, as stated, do not like the feel of double-tap, which is fine. To each their own. That being said, at least know the features of each drivetrain for a proper opinion. :beerchug:
Exp001
PostPosted: Fri Jul 13, 2012 12:05 am
I should have not typed SRAM that was a non-deliberate mistake. I changed the sentence around abit and left an error in. I am aware that with SRAM you can trim the FD. Although given the error pendrefu I think pointing out the error (wqhich is fine) and then adding what you did is a bit too much. You made assumptions about the error which may not be true.
PostPosted: Fri Jul 13, 2012 12:15 am
You are correct, I wrote too much.
Exp001
PostPosted: Fri Jul 13, 2012 12:23 am
allow me to re-iterate, Campy is out of the question, I have only Shimano/Sram compatible hubs.
And speedplays....NEVER again. not for me. no matter how much I tried to dial them in I could never ride them without knee pain. SPD-SL work for me and I'll be sticking with them.
thanks everyone for your input. Thru pure naivete I had no idea how affordable Sram Red from 1-2 seasons ago has become!
So far I think I'll be going w/ (although it's likely to change a couple dozen more times lol)
Force brifters and crankset
Red RD & FD
Rival BB and Brakes
Ultegra Cassette
KMC chain
PostPosted: Fri Jul 13, 2012 12:40 am
what do people think of the microshift arsis stuff? That sounds like an option too, but I can't find that much info about it.
EDIT: Looks like a boat anchor when compared to SRAM :oops:
Apparently my bikes were talking the other day & are undecided whether to upgrade the current rider or get a new one...
one of the schemers...
PostPosted: Fri Jul 13, 2012 4:08 am
SRAM Rival... :thumbup:
"black on black, is a crime"
PostPosted: Fri Jul 13, 2012 4:41 am
i was able to get the new sram red group off eBay for about 1.2k by buying the pieces one at a time. There gonna go on a caad10! :D
PostPosted: Fri Jul 13, 2012 5:12 am
Red RD & FD
Rival BB and Brakes
Ultegra Cassette
KMC chain
Switch to a force FD unless you can finds steel cage one
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
Users browsing this forum: Bing [Bot], djm, Exabot [Bot], Google [Bot], Google Adsense [Bot], HammerTime2 and 50 guests
There are no new unread posts for this topic. Chorus FD on Record gruppo?
MaxDaddy
10
600
Sun Feb 24, 2013 10:11 pm
MaxDaddy View the latest post
There are no new unread posts for this topic. Gruppo for lightweight winter build
Fluffman
12
1086
Tue Dec 25, 2012 7:54 pm
bm0p700f View the latest post
This topic is locked, you cannot edit posts or make further replies. Where should I spend $1000?
miskur505
Sat Jul 14, 2012 11:56 pm
bricky21 View the latest post
There are no new unread posts for this topic. Best way to spend £500
bikersdozen
12
992
Fri Aug 03, 2012 12:59 am
digitalnorbs View the latest post
There are no new unread posts for this topic. Best place to spend $2300
Elpimpo
38
2161
Fri Jul 06, 2012 8:12 pm
Timebandit415 View the latest post
It is currently Sun May 19, 2013 11:55 pm
