Post new topic Reply to topic  [ 9 posts ]
Which crank based power meter combo?
Quarq + Cannondale Hollogram + Stronglight chainrings 26%  26%  [ 5 ]
Quarq + Rotor 3D + Stronglight chainrings 32%  32%  [ 6 ]
Power2max 26%  26%  [ 5 ]
Other? 16%  16%  [ 3 ]
Total votes : 19
PostPosted: Thu Jul 12, 2012 7:13 am
Ok, so the Campy SRM is just too expensive.
It looks like whatever i choose, I'll be using Stronglight CT2 chainrings for their 11 speed compatability.
The new Quarq spider for Cannondale cranks looks very nice, quite light, pricey for a Quarq, but still not in SRM territory pricing wise: http://quarq.com/cannondale-quarq
So, appearance wise, this is going on a Campy build, on a Cinelli. I'm leaning towards the Cannondale setup "looking" nicer, but I don't mind the look of Rotor cranks on Campy setups - of course they look better on Red setups, but I think thats largely because we're more used to seeing them on pro level Red spec'd bikes.
On the weight side of things, the Cannondale setup has the edge, especially if I get their new 2012 SiSL2 setup: http://www.bikerumor.com/2012/06/21/upd ... ck-online/
Is there anything else to consider?
PostPosted: Thu Jul 12, 2012 7:47 am
10sp rings work fine with 11sp.
Been using them for thousands of km's now, no trouble.
PostPosted: Thu Jul 12, 2012 9:15 am
No issues on 10 speed cranks with 11 speed chainset. I have thm crank with 10 speed extralite chainring and lightning crankset with fiberlyte chainring.
Cervelo R2.5
Cervelo P2c
Cervelo R3
Parlee Z3
Parlee TT
PostPosted: Thu Jul 12, 2012 10:52 am
Serbelo, I think you have to factor in the difference between the BCD, 130 BCD crankset can't goes with 135bcd campag rings.
PostPosted: Thu Jul 12, 2012 12:54 pm
I voted "Other", but in retrospect it was really only a twitch response. I'm riding Rotor 3D cranks with Q-rings and a Quarq with Campy. Outside of the Q-rings, that's the same as your poll option to use Stronglight rings instead. I like Stronglight rings and used them before I switched to Q-rings (won't be going back to round rings FWIW), but if I was using Rotor 3D cranks and didn't want Q-rings I'd probably use Rotor round rings for the overall aesthetic, but Stronglights would perform just as well. FWIW, as others mentioned, 10-sp rings run fine with Campy 11, so your choice does not necessarily need to be limited to Stronglight.
PostPosted: Thu Jul 12, 2012 4:59 pm
THM m3 SRM and praxis rings... FTW
http://fairwheelbikes.com/cycling-blog/ ... ee-z5.html
PostPosted: Fri Jul 13, 2012 1:35 am
Thanks for the replies.
I really didn't mean this to turn into a "you don't need 11 speed chainrings to work, normal 10 speed chainrings will be fine with campy 11 speed". The only reason I mentioned it is because all the crank or power meter makers market to 11 speed customers with tag lines like "Campagnolo compatibility available with the use of Stronglight CT2 11 speed chainrings"
Anyway, im not about to use shimano or sram cranks on an otherwise Campy bike, but I get what a few of you have said; I don't need the Stronglight rings, I can just use the standard chainrings on either Rotor or Cannondale Hollogram.
PostPosted: Fri Jul 13, 2012 1:53 am
I have been using campy sr 11 with rotor cranks with rotor rings on a quarq for close to 2 yrs now. Customer service from quarq is second to none.
I did have some issues with the initial set up. The rotor rings require the front D to be set higher then my Colnago EPS braze on would allow. I had to dremel the cage a couple mm to allow clearance.
Since then I have moved the quarq set up to a C59 and a new set of campy sr 11 with no such issues.
PostPosted: Sat Jul 14, 2012 12:05 pm
Power2Max is another choice for you to consider.
I am using it for a year after I have used SRM PC V for 2 years. No problem so far for Power2Max.
The Great CarboniO
Users browsing this forum: Andrew69, Bing [Bot], bratz, Zak and 54 guests
There are no new unread posts for this topic. Recommend Crank-Based Powermeter for BB30 Ui2 Compact
415brian
Fri Nov 02, 2012 8:43 pm
415brian View the latest post
There are no new unread posts for this topic. Campy Finally Releases EPS Integrated Battery System!
audiophilitis
Tue Apr 02, 2013 7:32 am
doomith View the latest post
There are no new unread posts for this topic. 10 speed Shimano crank/rings on 11 speed group Shimano
bigcalves
11
1381
Wed Oct 10, 2012 10:06 am
BdaGhisallo View the latest post
There are no new unread posts for this topic. From campy 10 speed to 11speed
digitalnorbs
Sun Jun 24, 2012 7:25 pm
Powerful Pete View the latest post
There are no new unread posts for this topic. Red Exogram Quarq with Campy 11-speed?
bluingreen
Mon Jul 30, 2012 1:52 pm
Dammit View the latest post
It is currently Wed May 22, 2013 8:10 am
