Post new topic Reply to topic  [ 6 posts ]
PostPosted: Wed Jul 11, 2012 12:22 pm
hey guys;
sorry if this has been discussed already :oops:
I'm wondering what the differences are in the crank-arms of the Ultegra and the Dura-ace cranks (mainly weight wise :roll: ). I've spent a bit of time searching but I've only been able to find the differences of the complete crankset, I'm interested in just the crank-arms. Any info appreciated, I really have :noidea:
Apparently my bikes were talking the other day & are undecided whether to upgrade the current rider or get a new one...
one of the schemers...
PostPosted: Wed Jul 11, 2012 8:33 pm
Yep, weight. Stiffness is roughly equal. I believe only the 105 cranks are stiffer. But also heavier, which is of course more important :smartass:
PostPosted: Thu Jul 12, 2012 2:33 am
the 6600 cranks are stiffer and a bit heavier no more than 50 grams.
PostPosted: Thu Jul 12, 2012 5:26 am
I was under the impression that the 5600 crank arms (without rings) were lighter than the 6600 crank arms, but the 5600 chainrings are much heavier so 6600 crankset (with rings) ends up lighter. My 5600 bare crank arms (172.5 mm) weigh 580 g. Does anyone have bare 6600 crank arms to compare?
Visually, the 5600 and 6600 arms look the same, but the 5600 uses a thicker, but lighter aluminum axle while the 6600 uses a stiffer steel axle, although I did see one 6603 crank with an aluminum axle so there may be more out there. Hence the bare 5600 arms are lighter and the 6600 arms are supposedly stiffer, but frankly I cannot discern the difference between 5600, 7800, or indeed any other 24 mm axle crank that I have ever ridden.
The 7800 versus 5600 arms appear rather different. The 5600 arms are taller and beefier, while the 7800 arms appear more svelte and have different contours. From the side view, the 7800 arms taper from the axle to the pedal hole whlie the 5600 arms are pretty straight. The pinch bolts for the 7800 cranks are slightly shorter and thread into blind holes, while the 5600 crank uses through holes.
The q- and u- factors are consistant at 147 mm and 137 mm, respectively.
PostPosted: Thu Jul 12, 2012 8:47 am
for the record, a set of Ultegra 6600 cranks, they weigh 736g with chainrings and chain bolts (170mm).
PostPosted: Mon Jul 16, 2012 5:05 am
I'd say most of the extra weight on the Ultegras is due to the thicker-walled axle.
Try scewing a 7800 'end cap' on a 6600 axle like I did. :thumbup: Not even close.
Users browsing this forum: Bing [Bot], JamieL, rodebaron51, VMac and 70 guests
There are no new unread posts for this topic. Replace 7800 Dura Ace crank arms?
trysixty
Sun Dec 16, 2012 3:23 pm
sedluk View the latest post
There are no new unread posts for this topic. Black outer & inner chainring for SRM 7800 Dura Ace crank?
el condor
Sat Sep 22, 2012 10:23 pm
el condor View the latest post
There are no new unread posts for this topic. Look Keo Blade price differences, Canada vs. US
jspaceman
13
751
Thu Sep 20, 2012 5:26 pm
jspaceman View the latest post
There are no new unread posts for this topic. New Pedals, going from Dura Ace 7800
v70cat
34
2708
Sun Nov 11, 2012 11:36 am
mann2 View the latest post
There are no new unread posts for this topic. Bianchi 928 lugged carbon after a few rides. 7800 DA
skiezo
Sat Mar 16, 2013 9:02 am
Ride-Fly View the latest post
It is currently Fri May 24, 2013 3:45 pm
