It is currently Fri Dec 15, 2017 7:51 am
Post new topic  Reply to topic  [ 22 posts ]  Go to page 1 2 Next
 Post subject: Veloflex Master 23
PostPosted: Mon Jul 09, 2012 1:46 am
I've ridden the 22 version for the past couple years and loved them. So I was very excited to see the new 23 version this spring and ordered a set. Mounted them this weekend and they are actually slightly narrower than the 22? I even checked them with a pair of digital calipers. Did I get some 22s marked as 23? Anyone have the 23 that is actually 23?
Thanks.
 Post subject: Re: Veloflex Master 23
PostPosted: Mon Jul 09, 2012 6:16 am
Did you mount them on the same rim? Did you measure your old 22's on the same rim with the same pressure? Rim width and tire pressure effect the width of the tires when mounted.
PostPosted: Mon Jul 09, 2012 6:45 am
I bought some a couple of months ago and found the measurements, both new off the wheels and on the same rims at the same pressure, to be identical to some old 22s I had in stock and on wheels.
PostPosted: Mon Jul 09, 2012 7:02 am
tires do seem to "grow" a little width wise over time.
PostPosted: Mon Jul 09, 2012 8:22 am
I was comparing the measurement of new 22s with new23s and mounted 22s and 23s since I had tires both mounted and never used.
PostPosted: Mon Jul 09, 2012 11:50 am
Tubbie Guru
Hi,
The "old" 22mm Veloflex tyres already had a tendency to come in at slightly wider than 22mm (22.5mm being the average) but still within Veloflex range of allowable tolerance.
From what I measured so far they're still the same as before and to put it quite frankly, I'm glad they haven't changed a thing.
Ciao, ;)
PostPosted: Mon Jul 09, 2012 12:22 pm
I can't speak to the Veloflex Master but for both the Veloflex Carbon and Veloflex Roubaix the change from 22mm to 23mm (Carbons) and from 24mm to 25mm (Roubaix) the change is real and measurable. I also thought at first that it might be just a marketing name change to go along with the wider tire trend. But I have mounted both old and new Carbons, Roubaixs and the newer all black Arrenberg (25mm) on identical rims and measured them. The new tires are indeed about a millimeter wider. I for one appreciate the move from 22 to 23mm for the Carbons. Haven't had the opportunity to try the new 25's to see how they feel when compared to the 24's but I have a set of 25mm Arrenbergs (black Roubaixs) that I will be able to try out shortly.
Colnago C60 - PR99
C59 Five Years Later
My Special Colnago EPQ
Trek Emonda SL Campagnolo SR
PostPosted: Tue Jul 10, 2012 3:07 am
Thanks for the comments, I was hoping Veloflex's 23 would actually be wider than their 22s. I can't stress enough how good these tires are for clinchers, just wish they were a bit wider.
PostPosted: Tue Jul 10, 2012 6:56 am
So i've just had my first ride on a set of veloflex masters. Love them, however installing them was a PIA. I had no problem getting the beads onto the rim, it was getting the tube to sit flush with the rim that was a hassle. Long gone are the days where I can install a tyre without levers.
Would you guys be able to share any tips/tricks to installing the masters?
PostPosted: Tue Jul 10, 2012 11:22 am
Tubbie Guru
Hi,
Well, you should not use tyre levers to install a Veloflex tyre. It overstretches the bead locally which may in turn lead to a blowout especially when using latex inner tubes.
Ciao, ;)
PostPosted: Fri Mar 07, 2014 8:04 am
I have Master on my hands right now and in the Operating instructions is written: Do not use carbon fibre rims.
:shock:
"Nothing compares to the simple pleasure of a bike ride"
Jamis Renegade Expert
Spark 900 RC
PostPosted: Sun Mar 09, 2014 5:41 am
I've found that the new 25 is the same as the 23, which is the same as the old 22....
Went back to Vittoria, their 25 is actually 25.
PostPosted: Sun Mar 09, 2014 12:42 pm
:shock:
Do you know why not??
Enviado desde mi iPhone con Tapatalk
PostPosted: Sun Mar 09, 2014 3:38 pm
No. I hope someone can explain.
Spark 900 RC
PostPosted: Sun Mar 09, 2014 7:40 pm
Tubbie Guru
Hi,
I guess it has to do with heat.
To make sure maybe you could send an e-mail to the distributor in Tallinn:
spordipartner@gmail.com
Ciao, ;)
There are no new unread posts for this topic. Colnago master Arabesque build help
markyboy
Fri Apr 14, 2017 3:18 pm
Zakalwe View the latest post
There are no new unread posts for this topic. Colnago Master frame size question
stam1668
Sun Jan 29, 2017 12:29 pm
kgt View the latest post
There are no new unread posts for this topic. Long Distance Bike Ritchey Road Logic 2.0 vs Colnago Master
3Pio
38
3964
Tue Jan 24, 2017 1:49 pm
Marin View the latest post
There are no new unread posts for this topic. Which veloflex tubular for HED Stingers?
SpecializedColnago
Tue Jun 13, 2017 1:54 pm
Geoff View the latest post
There are no new unread posts for this topic. Veloflex corsa 25mm clincher tire question
poppiholla
14
1811
Wed Jan 25, 2017 7:56 am
poppiholla View the latest post
Users browsing this forum: GothicCastle and 33 guests
