Post new topic Reply to topic  [ 20 posts ]
Go to page 1, 2  Next
PostPosted: Sun Jul 08, 2012 9:10 pm
So what does everyone to clean pad material from aluminum brake tracks?
I have tried a number of methods and am looking for input on what works best.
PostPosted: Sun Jul 08, 2012 9:23 pm
Mavic used to make a cleaning block for that purpose which was very effective. Don't know if it's still available.
PostPosted: Sun Jul 08, 2012 10:11 pm
Windex and rag. I'm serious... Works perfectly - my LBS gave me that trick.
Rob
PostPosted: Sun Jul 08, 2012 11:13 pm
Whatever multipurpose cleaning product my wife allows me to use from under the sink. Honestly.
Cervelo R3, Campagnolo Chorus/Record mix... pastatrails.blogspot.com
PostPosted: Mon Jul 09, 2012 12:18 am
Mavic rubber still available! Used on mine recently and came up a treat.
PostPosted: Mon Jul 09, 2012 2:15 am
Usually I just wipe it off with a paper towel. But I had some persistent brake pulsing on an XR270 and cleaned its brake tracks off with acetone (on a paper towel). That cut the pulsing down quite a bit.
PostPosted: Mon Jul 09, 2012 2:17 am
If the rims aren't too scuffed up, a paper towel with some isopropyl alcohol should do the trick. If they are real bad, then you can get what is called a gummy stone, usually reserved for tuning ski edges. They are pretty cheap, and should help to clean off any excess debris or imperfections.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Mon Jul 09, 2012 3:15 pm
I found brake cleaner (the automotive product) works the best for me. Small amount on a rag and rims look brand new in a couple minutes.
PostPosted: Mon Jul 09, 2012 3:33 pm
Administrator
I just use a green scotchbrite pad. Works great and can be used over and over again.
PostPosted: Mon Jul 09, 2012 5:48 pm
White spirit works great (in The Netherlands we call it 'wasbenzine'). Way cheaper than most brake track cleaners.
My Renovo R1 wooden bike project
Check it out: the most amazing vintage Colnago, Merckx and Pinarello collection
PostPosted: Mon Jul 09, 2012 5:58 pm
wasbenzine is something different than white spirit. It is a very effective cleaner for brake tracks :thumbup:
So is acetone, white spirit, dish washing soap and a scotchbrite pad, petrol, thinner, brake cleaner and isopropyl alcohol. :D
Just use whatever you've got lying around and also use the most effective cleaner: elbow grease.
    2011 Cannondale Flash F1
      2010 Cannondale Caad9
        2000 Cannondale Caad 4 aero
          1999 Cannondale Caad1
            ???? Concorde SS
PostPosted: Mon Jul 09, 2012 6:28 pm
I would not advise to use acetone as this will dissolve decals and stickers that are not under the clear coat and it will dissolve some clear coats.
PostPosted: Mon Jul 09, 2012 7:13 pm
What are the gummy stones made from? I googled it but didn't see anything.
PostPosted: Mon Jul 09, 2012 7:14 pm
What are the gummy stones made from? I googled it but didn't find any info about the material.
Thanks.
PostPosted: Mon Jul 09, 2012 7:33 pm
Thanks.
Good question actually. I am not totally sure on this one. If I had to take a guess though I would think that it is some sort of rubber compound with steel shavings in the rubber. They remove minimal amounts of material seeing as they are designed for 2mm thick ski edges.
If you decide to go with one, I would say go with the medium softness.
Post new topic Reply to topic  [ 20 posts ]  Go to page 1, 2  Next
Users browsing this forum: 573, caballero, Google Adsense [Bot], rijndael, RippedUp, wrcompositi and 52 guests
There are no new unread posts for this topic. Which carbon clincher wheelset has the best brake track?
tmanley
16
2162
Sat Oct 06, 2012 6:39 am
VNTech View the latest post
There are no new unread posts for this topic. Carbon rims - worn brake track?
Permon
Sun Oct 07, 2012 10:06 pm
Permon View the latest post
There are no new unread posts for this topic. Deeper section AL rims, no brake track.
deltasierra
9
934
Mon Oct 08, 2012 12:47 pm
Guyeclipse View the latest post
There are no new unread posts for this topic. Easton EC90SL delaminating brake track
climr
Wed May 23, 2012 11:53 pm
MDiddy View the latest post
There are no new unread posts for this topic. Cheap(ish) light(ish) aero wheels w alloy brake track
Kurt
19
1863
Fri Sep 21, 2012 10:45 am
Phill P View the latest post
It is currently Tue May 21, 2013 2:03 pm
