Post new topic Reply to topic  [ 12 posts ]
 Post subject: Front fork rake?
PostPosted: Sun Jul 08, 2012 8:14 pm
hello,I'm new here and do have a problem with my Litespeed Arenberg it is very nervous on his steering in the way that handsfree riding
is nearly impossible would it be possible to improve the straightoutstability with a frontfork with a greater fork rake ?
Now i have a Pro 1" carbon fork with alu steerer wich I think has a fork rake of 43
Thks
 Post subject: Re: Front fork rake?
PostPosted: Mon Jul 09, 2012 5:49 am
Sirius wrote:
Hello,I'm new here and do have a problem with my Litespeed Arenberg. It is very nervous on his steering in a way that hands free riding
is nearly impossible. Would it be possible to improve the straightout stability with a front fork with a greater fork rake ?
Now i have a Pro 1" carbon fork with alu steerer which I think has a fork rake of 43.
Thks
More stability is achieved with more trail. If you want more trail you need less rake.
I think the Arenbergs are regarded as handling very nicely. Is that the original fork?
r o y g b i v
PostPosted: Mon Jul 09, 2012 10:24 pm
Thanks for the info and no it isnt the original fork I bought the frame last year brandnew(fair price) but without the front fork so i had to search a 1" fork and the only one I could find was the Pro fork . The original fork was a Look fork yellow with silver and when I look at the history of Litespeed it had a rake of 40 or 43 (depending on the size of the frame) but about the trail nothing was published
PostPosted: Mon Jul 09, 2012 10:27 pm
what size is your bike?
PostPosted: Mon Jul 09, 2012 10:56 pm
Here is a really informative geometry chart for the Arenberg. They even go on to explain their fork length and headset stack height both which will have effects on the geometry though the effects will be very slight, and unnoticeable to most.
PostPosted: Tue Jul 10, 2012 6:47 pm
Can't imagine any thing other than a wobble making sans hands riding sketchy. Unless you're negotiating curves. I replaced the 49mm offset, 470gm stock fork on my Specialized Roubaix with a 45mm Reynold's Ouzo and couldn't tell any difference in the steering.
PostPosted: Tue Jul 10, 2012 8:50 pm
thanks again for the info @Bricky 21 the size of my Arenberg is 55 and besides the nervous steering I am very happy with the riding qualities of the bike @ lechat I never had any speed wobbles but taking something out of your rear pocket is sometimes tricky even at low speed and especially with a little sidewind (Marchisio wheels 28mm high)
PostPosted: Tue Jul 10, 2012 10:15 pm
I'm assuming that you're able to ride other bikes no handed and that this problem is isolated to the Arenberg? If that is correct then there is something wrong with the frame, fork, or headset(either not straight or installed correctly. No way a fork offset change of 3mm would turn that particular bike into a poor handling machine. First thing I'd check is the headset adjustment, next I'd try and borrow a fork off a bike that I knew rode correctly, and if all else fails I'd have the alignment of the frame checked. Also, that frame has to be over 10 years old, so are you positive it's new/unused?
PostPosted: Wed Jul 11, 2012 3:36 am
Check you cable housing lengths. Lift the bike in the air and tilt it forward and back. The bars should stay straight. If your cable housing is wrong it will push the bars to one side. This makes riding no hands very difficult.
swinter wrote:
Mr.Gib got it right
PostPosted: Wed Jul 11, 2012 1:37 pm
I have to disagree with bricky and say that a few mm of rake can make a difference.
I have a frame that originally came with a 43mm fork that was impossible to ride hands off. A change to a 40mm fork made it possible. May not sound much but it translates to about an additional 6mm trail.
dangerous curves ahead
PostPosted: Wed Jul 11, 2012 3:12 pm
I would agree if we were talking about a bike already designed to be nervous, but you should be able to read a book while riding that Arenberg.
Since I'm on vacation and my coffee is too hot to drink I decided to mock it up in bike cad using the geometry chart from above with the fork length(368) and headset stack height(12mm) listed in it(1'st picture). Then I changed only the fork offset from 40mm to 43mm(second pic). In the third I kept the additional 3 mm offset, and added 4mm to the fork length 1.7 mm to the bottom stack height.
Stock 55 Arenberg + 3mm offset + 4mm fork length + 1.7mm bottom headset cup.JPG
Stock 55 Arenberg + 3mm offset + 4mm fork length + 1.7mm bottom headset cup.JPG [ 93.3 KiB | Viewed 353 times ]
Judge for yourself, but imo when starting out with the stock 55 geometry it would be really difficult to render that bike unstable with such a small change in fork offset.
To the OP do you have or have you had another bike that you could ride no hands( same saddle height/setback and cleat placement)?
PostPosted: Wed Jul 11, 2012 4:58 pm
@bricky21 yes i do have another(alu) bike and it is possible to read the newspaper on it ,it's also a 55cm frame with the same height of wheels but with a straight blade alu fork so yes I do have the skills to ride handsfree on it thanks again for all the supply of info i will check all the details and if i dont get out off it i 'll be back
Users browsing this forum: Anders, BmanX, Google Adsense [Bot] and 54 guests
There are no new unread posts for this topic. 2010 CERVELO RS 54 fork rake
digitalnorbs
Wed Apr 03, 2013 7:07 pm
digitalnorbs View the latest post
There are no new unread posts for this topic. Front wheel not centered in fork
Greenduck
Sun Jul 29, 2012 8:03 pm
em3 View the latest post
There are no new unread posts for this topic. Attachment(s) Whisky Parts Co. No.7 carbon front fork
SWijland
Sun Aug 05, 2012 2:08 pm
Wingnut View the latest post
There are no new unread posts for this topic. Looking for carbon 1 1/8" forks with 43 rake & 365 A to C
dieselgeezer
Thu Mar 14, 2013 11:59 pm
cyclenutnz View the latest post
There are no new unread posts for this topic. Fork expander för Colnago fork ?
PSM
Thu Nov 22, 2012 11:03 am
PSM View the latest post
It is currently Sun May 19, 2013 6:10 pm
