Post new topic Reply to topic  [ 15 posts ]
PostPosted: Sun Jul 08, 2012 5:35 pm
Hi,
i am about to build a pair of wheels with Alpha 340 rims 28 rear and 24 front and Tune Mag 170 rear hub and Mig 70 front hub. I want to use 14mm prolock nipples and cx ray spokes.
I have two questions:-
1. Spoke length calculated is Rear 3 cross Drive 293, Non Drive 291. Front 2 cross 288.
Before i waste my time and money ordering the spokes does this seem right ?
2. If i use 14mm nipples should i reduce the spoke length ?
My logic says no don t reduce the spoke length ?
Thanks.
PostPosted: Sun Jul 08, 2012 6:03 pm
Thanks.
Correct.
www.ergottwheels.com
PostPosted: Sun Jul 08, 2012 11:49 pm
Decide beforehand if you plan to use nipple washers as per Stans recommendations before deciding on a final spoke length as they are around a mm thick.
Although, I think the new revision of the Alpha 340's (if that is what you are getting) may already have a beefed up spoke bed that doesn't warrant the use of the washers.
I built mine on the old version without and they have been fine, but originally intended to use them and found the spoke lengths were on the short side if I used the washers.
Something to take into consideration at least.
PostPosted: Mon Jul 09, 2012 1:36 am
I just checked the spoke lengths and those look good. The 12mm nips should do just fine too.
http://www.zencyclery.com
http://www.wheelbuilder.org
PostPosted: Mon Jul 09, 2012 3:05 pm
Maybe the wheel builders can chime in with more info but I think you will need to go with a 2X on the rear with a 28H hub.
www.royalbicycles.com
PostPosted: Mon Jul 09, 2012 3:25 pm
Well the rule of thumb is divide the spoke count by 9 for maximum crossings. 9 goes into 28 3 times so 3 should be the maximum crossing. Otoh I once built a 36 hole wheel with a Dura-Ace 7800 hub and an open pro rim with 4 cross and I just barely ran into the spoke heads.I'm not sure if the flange diameter plays a role in that though? Fwiw Alchemy recommends 3cross for the drive side of 28 hole ORC hubs.
PostPosted: Mon Jul 09, 2012 3:33 pm
The main problem with 3x wouldst be is that the angle is too extreme and the spokes is over the flange.....
PostPosted: Mon Jul 09, 2012 3:34 pm
I used the same parts on one of my builds, but I went 24/28h, radial front, radial rear NDS, and 2X DS (as suggested by troy Watson for NDS rear). I used Spocalc, but can't find the actual lenghts now...
Came just right.
Louis :)
http://www.ccsalma.com
PostPosted: Mon Jul 09, 2012 5:14 pm
You can go 3x on a 28H rear wheel but the hub flange has to be small enough. The left side flange is small enough for 3x I think but the right side is not. So it will be 2x for these hubs I think.
www.thecycleclinic.co.uk
PostPosted: Mon Jul 09, 2012 6:04 pm
3x on the rear shouldn't cause issues with crossing over the flange on this hub. As mentioned, if a hub had a massive flange, then 2x may be better even in a 28. With this hubset though, 28 hole 3x should be the ticket.
PostPosted: Sat Aug 04, 2012 9:53 am
Considering the same components but quick query on build. I weigh 76kg. Running a340's should I stick with 24/28 or can I drop to a 20 on the front (from reviews I think 24 on the rear will be too low for this rim for my weight). Also any views on spoke lace patterns, am I better with radial on the front?
Finally, if I go for a budget build, would I see much reduction in performance/durability etc using bhs super lights?
PostPosted: Sat Aug 04, 2012 6:01 pm
Radial on the front is going to be much easier to lace up.
I laced up a radial front wheel of mine in about ten minutes.
My drawings:
http://www.facebook.com/andrewlivingstonart
My bike:
http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=107451
PostPosted: Sat Aug 04, 2012 10:29 pm
Zen maybe right. What is the flange diameter limit them for 3x on 28H hubs?
PostPosted: Sun Aug 05, 2012 1:55 am
I weigh a little more than you and have had no problem with the old 350g rim with 24 spokes in an Alchemy Orc hub, ~10k miles. The front is an 18h. The rims weigh ~390g now. 28r, 20f should be fine... but everybody is different.
The only issue with 3x lacing and 28h is if the flange is very large you will get an acute angle where the spoke enters the rim.
formerly rruff...
PostPosted: Tue Sep 04, 2012 12:22 pm
Hey,
I am looking at getting the same hubs for a new wheel build but i read that tune hubs cant be laced radial as it voids the warranty. Can anyone confirm or deny this?
Users browsing this forum: Exabot [Bot], krzysiekmz, la rosa and 50 guests
There are no new unread posts for this topic. Stans ztr alpha 340 rim bulge
Tenlegs
11
628
Sun Mar 31, 2013 2:26 am
eflayer View the latest post
There are no new unread posts for this topic. Velocity A23 or Stans Alpha - your views
DJT21
9
942
Mon Feb 25, 2013 3:44 am
winky View the latest post
There are no new unread posts for this topic. AC Road Tubeless vs Stans ZTR Alpha Pro
styrrell
Tue Feb 05, 2013 10:24 pm
styrrell View the latest post
There are no new unread posts for this topic. Tires blowing off Stan's Alpha 340 rims
[ Go to page: 1 ... 4, 5, 6 ]
WMW
75
6775
Sat Jun 15, 2013 6:09 pm
tinozee View the latest post
There are no new unread posts for this topic. Tire suggestion for stans ztr alpha 340 rims
fitty4
20
1399
Thu Jan 17, 2013 7:53 pm
MarkMcM View the latest post
It is currently Thu Jun 20, 2013 3:09 am
tune MAG 170
