Post new topic Reply to topic  [ 1 post ]
PostPosted: Sat Jul 07, 2012 3:34 pm
Just got a new Powertap G3 hub, and I wanted to check that the firmware was up to date. Downloaded the PowerAgent software and removed the power cap from the hub.
First source of confusion was the discrepancies between the G3 manual and advice provided online and in the PowerAgent software itself. The manual doesn't mention anything about removing the battery before connecting the powercap to the PC, and the FAQs on the website imply that the battery should still be in place (it mentions not leaving it connected for too long in case you drain the battery). However, other 3rd party advice I found online suggests that it is necessary to remove the battery, most of the time the powercap isn't recognised by the computer unless you do this, and after updating the firmware the PowerAgent software warns you to disconnect the power cap from the computer before re-inserting the battery! So I found out the hard way that removing the battery first is necessary and am hoping nothing has been damaged as a result of not doing this the first time...
Secondly, I can't figure out if the firmware update has been implemented correctly. When I first connected the powercap, PowerAgent told me I had v. 16.000 installed and allowed me to update to v. 16.021. Afterwards, when I check the status it tells me that I have the latest version (16.021) installed. However, every time I disconnect the powercap from the computer and reconnect it, PowerAgent tells me I still have the older firmware and updates it again... How do I really know what firmware I have installed?
Users browsing this forum: BeeSeeBee, Bing [Bot], Google [Bot], Google Adsense [Bot], mdeth1313, TOflat and 75 guests
There are no new unread posts for this topic. Ultegra Di2 New Firmware
goodboyr
16
3121
Fri Sep 14, 2012 7:27 pm
Toby View the latest post
There are no new unread posts for this topic. Hacking Di2 firmware to do single-lever shifting
freeloader
7
1236
Fri Jan 04, 2013 6:20 pm
Squint View the latest post
There are no new unread posts for this topic. Powertap G3 Wheelset
Ghost234
Sat Jun 09, 2012 2:26 am
12x23 View the latest post
There are no new unread posts for this topic. Help! Powertap calibration is WAY off!
Ghost234
Mon Jun 11, 2012 7:42 pm
mjduct View the latest post
There are no new unread posts for this topic. Powertap SL 2.4 bearings
Master-Ti
Sun Jun 17, 2012 12:14 am
eric View the latest post
It is currently Wed May 22, 2013 6:35 pm
