Post new topic Reply to topic  [ 3 posts ]
PostPosted: Sat Jul 07, 2012 2:47 am
Recently bought a 2009 hi mod Cdale 60 cm. Its at 14.8 with full 7900 DA but has the hollogram crankset. Also has some heavier clinchers etc. I plan to swap on my Bonty XXX lite carbon tubies and zero gravity brake set.
I also want to swap over to SRAM red 2012/13 or whatever the hell the year is with front der. yaw adjustment. I know I should in theory run the whole SRAM group but would prefer to just swap out levers and both ders.
Anybody know:
1. Can I use the 2012/13 levers and front der. with the hollowgram cranks?
2. Can I use a SRAM red 2011 rear der. if levers and front der. is 2012/13
3. Assuming I use Sram red levers front and rear ders. vs. the DA what the weight shave will be?
4. What is weight shave of zero gravity vs. 7900 DA calipers?
I am sure someone will flame me for not using search but I tried that and you only get 200000 hits for SRAM red! :cry:
PostPosted: Sat Jul 07, 2012 2:59 am
1. yes
2. yes
3. look it up and do some sums.
4. about 90g or so. you can't really use 7900 brakes with sram red. Either get sram brakes, zero-g, revl, TRP/tektro or some other brake that is designed around a standard (sram/campagnolo/7800) cam ratio.
PostPosted: Sat Jul 07, 2012 3:39 am
Thanks I wasn't sure on mixing the hollowgram crankset seems I'd read there could be some chain rub issues. Was more confident I could use the older gen rear der but thought I'd throw it out there for any experience with it.
Users browsing this forum: drainyoo, Exabot [Bot], Google [Bot], Google Adsense [Bot] and 48 guests
There are no new unread posts for this topic. Attachment(s) 60cm CDale Supersix--13.71 lbs how low can I go!?
sandico
19
1684
Sun Oct 28, 2012 4:49 am
AttacknowAttackoften View the latest post
There are no new unread posts for this topic. Attachment(s) CDale EVO chain catcher
RobH
14
1168
Sun Jan 27, 2013 3:07 am
eric View the latest post
There are no new unread posts for this topic. Attachment(s) Upgrading Sram Red to 11sp
[ Go to page: 1, 2, 3, 4, 5 ]
monchito
68
7912
Mon Jun 03, 2013 3:35 am
KLabs View the latest post
There are no new unread posts for this topic. Upgrading Ultegra Chainset and BB71-41 BB
tonto69
Sun Apr 14, 2013 4:27 pm
tonto69 View the latest post
This topic is locked, you cannot edit posts or make further replies. Upgrading enve 6.7 to shimano 11 speed
trilocus
Wed Dec 05, 2012 1:04 pm
upside View the latest post
It is currently Thu Jun 20, 2013 5:00 am
