Post new topic Reply to topic  [ 23 posts ]
Go to page Previous  1, 2
PostPosted: Sun Jul 08, 2012 5:35 am
Juanmoretime wrote:
I ride a smaller frame for two reasons. As mentioned before the shorter wheel base quickens the handling and something I prefer. Second is it allows more drop so I can get my back flat. I have disc issues and a flat back decompresses my spine allowing me to ride pain free.
Sounds like you just need a good custom built frame...
"It never gets easier, you just go faster..." - Greg Lemond
"Because technology alone is a poor substitute for experience." - Richard Sachs
PostPosted: Sun Jul 08, 2012 10:30 am
Administrator
I might agree if I had a very long or short stem, huge spacer stack or an unusual amount of seat post showing. I don't to any of those and I could ride one size up and still could say no to those three.
PostPosted: Sun Jul 08, 2012 7:30 pm
I always chose the biggest size that I was still comfortable with, but with the last frame that I received for long term test, I had to choose a smaller size. Why? The manufacturer uses size specific tube diameters and carbon layup for each size, and the XL I tried for a few days was way to stiff and harsh: it is probably designed for the 80-100 kg rider, and I only weight 69 kg @ 186 cm tall. I then tried the smaller (which I found out weights almost 100 gr less as opposed to the usual 30-40 gr/size increase!) was much more comfortable, the 20 mm longer seatpost also helps. The stack and reach differenc were corrected by a slightly longer stem and more saddle setback. So first time I ride a frame too small for me... and I actually like it!
PostPosted: Sun Jul 08, 2012 11:53 pm
Fit is my number one must on a frame. It effects comfort and handling. IMO a to small frame seldom has proper weight distribution. Proper geometry based on my size is not negotiable for me. I'd sooner wear knickers that are to small
WW Velocipedist Gargantuan
PostPosted: Tue Jul 10, 2012 7:18 pm
interesting comment peruffo, do you know if other / most manufacturers do the same? actually, are you sure about the one for your bike adopting different tubes for different sizes? I wouldn't expect that, at least one tube profile for each size. maybe there is a couple, one for smaller sizes, one for biggers.. whatever, would like to know for sure.
as for your comment regarding weight differences, I'd add that for very light carbon frames as SS evo or the R5, Ive seen 20-25 gr differences between sizes 56-54.. So for the OP (size 51 or smaller) the weight difference should be even less, defenetly not worth it - as one cm extra of stem (Ive measured for the 3T arx) adds about 6-8 gr. so if you need 2 more cm in your stem, and a few cm of extra seatpost, that is likely to balance out the weight savings on the smaller frame.
having said all that, I 100% agree that fitting is paramount, but in my case, I used to run a 58 caad and swapped it for a 56 and feel so much better, faster handling, etc, being 1,86m tall (most bike fits I did would put me in between sizes as well). so the only real piece of advice I have is the one we less want to hear: try both sizes, same wheels and everything else if possible
PostPosted: Tue Jul 10, 2012 7:27 pm
Tour Magazine tested a ton of frames in three different sizes and usually the smaller ones were stiffer, but there were exceptions. IIRC Trek and Parlee were among them, but it's been a while.
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Tue Jul 10, 2012 8:15 pm
Seat height and reach can usually be accounted for with a longer seat post or longer stem. And given most modern frames have begun to increase stack across the board for the more casual riders, a size small might allow you to achieve a more aggressive position. However, head tube length is your limiting factor with Cannondale (they are on the relatively short end of the spectrum), and you may end up using spacers to get a little more stack.
Either way, I don't buy the weight saving argument. I would imagine that a centimeter of a frame's tubeset is lighter than a centimeter of stem, spacer, or seat post.
PostPosted: Tue Jul 10, 2012 10:12 pm
and a small frame may be stiffer but the longer stem, seatpost will not be
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
Users browsing this forum: Bing [Bot], lechat, OrPe, wassertreter and 39 guests
There are no new unread posts for this topic. Replacing Red for heavier Ultegra Di2, worth weight penalty?
Tamu8104
Thu Nov 22, 2012 1:52 am
Tinea Pedis View the latest post
There are no new unread posts for this topic. Weight Difference 58 frame / 54 frame ?
Pepijn2010
Fri Nov 09, 2012 10:15 am
Pepijn2010 View the latest post
There are no new unread posts for this topic. How much time can we save? Post all your silly aero upgrades
[ Go to page: 1, 2, 3, 4 ]
SWijland
58
4096
Wed Jul 11, 2012 4:44 pm
prendrefeu View the latest post
There are no new unread posts for this topic. Attachment(s) Trek Domane Frame weight?
darth
Tue Nov 06, 2012 4:09 am
Zen Cyclery View the latest post
There are no new unread posts for this topic. CAAD8 frame weight = only 1175g!
cmd
Wed Feb 06, 2013 5:31 pm
User Name View the latest post
It is currently Sun May 26, 2013 5:58 am
