Post new topic Reply to topic  [ 39 posts ]
Go to page 1, 2, 3  Next
PostPosted: Thu Jul 05, 2012 10:34 pm
I have 2012 Rose Carbon Pro RS
So today I got it built, beautiful. Very happy with the end result. Great frame, stiff, fast, really smooth ride and the Ultegra DI2 is just flawless. I really love it. The only thing is that my LBS couldn't insert the DI2 cables into the frame and this frame takes Ultegra DI2
Check this link http://www.rosebikes.co.uk/article/rose-carbon-pro-rs-3100-compact/aid:529168
so it is all external right now which is not good. This frame built to take it internally. I'm checking what's the catch here. If anyone knows I would love to her your advice.
Here some pictures
I am here: http://tapatalk.com/map.php?lto4dc
PostPosted: Thu Jul 05, 2012 10:53 pm
I just built a Colnago Di2 C59. Wouldn't you know it the holes weren't big enough, I just used a small Dremel sanding head part or whatever you call it and made the hole's bigger, I'm sure you LBS have done/can do it if your not comfortable sanding a brand new carbon frame.
PostPosted: Thu Jul 05, 2012 11:05 pm
but it doesn't make any sense because this same exact frame taking DI2. As I show in the link I have attached. (the Rose Model 3100) is exactly the same frame I have. So why do I need to change the holes or to assume they are not big enough?
I am here: http://tapatalk.com/map.php?1jpls4
PostPosted: Thu Jul 05, 2012 11:32 pm
Here are few more pictures on the cables close up
PostPosted: Fri Jul 06, 2012 12:18 am
There are 2 wiring harness' 1 for external(which you probably have) and 1 for internal
http://www.wiggle.co.uk/shimano-dura-ace-9070ultegra-6770-di2-frame-cable-set/?utm_source=google&utm_medium=base&utm_campaign=uk&utm_content=Shimano-Shimano_Dura_Ace_9070%2fUltegra_6770_Di2_Frame_Cable_Set-Black
Probally not what you wanted to hear but I hope that helps
Bike looks cool just put the saddle level!
PostPosted: Fri Jul 06, 2012 12:48 am
With the old dura ace di2, there were distinct wire kits for internal, external, and everything in between. For ultegra di2, everything is in pieces, with only the junction box being clearly for either internal or external. You have the internal one. I cannot see what the hold up is, there must be some housing stop or cable liner in the holes keeping the plug ends from fitting.
What measurement are you getting for the frame hole sizes?
Edit:
What is the silver ring inside the right cable housing stop at the top of the down tube? Im assuming the mechanical cables are bare inside the frame, correct?
PostPosted: Fri Jul 06, 2012 12:51 am
One other thing I noticed was there is no provision for any cable to exit the frame for the front DR.
PostPosted: Fri Jul 06, 2012 2:39 am
Ouch - all those wires taped here and there - that hurts to look at.
I must ask - what is a "Rose" - is it an open mold Tawain frame.....if so then I wouldn't be surprised by a lax of QC. And also wouldn't be surprised by lack of incentive by a shop to make it perfect......
Anyways, frame builder vs shop that built it - someone needs to step up with a solution versus all that tape and looped wire - but hope all you require is the internal wiring kit :D
PostPosted: Fri Jul 06, 2012 2:51 am
Do some brands have two versions of the same model? While the main photo in the link shows Ultegra with internal routing, the inset photo shows normal cable housing...so maybe Rose has two versions.
Either that or you have to remove something in the cable stops.
As previously mentioned there are no "internal" or "external" wiring kits for Ultegra Di2 and the new (e-tube) wiring system, just the internal and external junction box. The wiring is universal for internal and external. You just buy different lengths and the correct junction box.
PostPosted: Fri Jul 06, 2012 3:22 am
Yikes that's quite the ugly wire job.
Are you sure the don't have "identical" di2 and a separate mechanical frame with the same paint job...
It just looks like a catalog frame to me so perhaps the use the same mould with different setups...
Flickr
Tarmac SL3 Project Yellow
Follow on Instagram
PostPosted: Fri Jul 06, 2012 6:19 am
Have you tried contacting Rose directly? I have used their webshop (but only for a few small parts: not complete bike) several times, and they seem like a VERY serious dealer, I would be VERY surprised if they wouldn't be able to help: Their service have always been fine with me.
PostPosted: Fri Jul 06, 2012 6:45 am
Edit:
the mechanical cables are only for the brakes and its running inside, if I understand you correctly.
PostPosted: Fri Jul 06, 2012 7:22 am
first of all take another mechanic, the built looks crap and even with the cables outside it can look good (but never with so many miles of electric tape).
Don't know where the catch with this frame is but so far I succeeded in making every frame suitable for internal routing (but sometimes drilling is nescesary, but no problems whatsoever with reliablilty).
PostPosted: Fri Jul 06, 2012 7:26 am
What is that Garmin mount?
PostPosted: Fri Jul 06, 2012 10:05 am
how is the drilling, is it dangerous for the frame?
Also anyone knows if the internal junction box of the Ultegra DI2 is waterproof like the external box?
I am here: http://tapatalk.com/map.php?iginj5
Post new topic Reply to topic  [ 39 posts ]  Go to page 1, 2, 3  Next
Users browsing this forum: Bing [Bot], djconnel, Google Adsense [Bot], ipaul, lechat, rijndael and 39 guests
There are no new unread posts for this topic. Best way to replace internal cable routing
ninjanoir78
10
884
Wed May 29, 2013 3:43 am
spartan View the latest post
There are no new unread posts for this topic. Internal routing outer cable Campagnolo 11s
chickenbourne
7
408
Fri Jan 11, 2013 4:18 pm
bontie View the latest post
There are no new unread posts for this topic. Cleanest way for DI2 on non-internal frame
L3X
Mon Jul 16, 2012 10:16 pm
bm0p700f View the latest post
There are no new unread posts for this topic. How to put DI2 internal on a Cervelo R3 BB Right frame?
bruno2000
Fri Mar 01, 2013 2:48 pm
bruno2000 View the latest post
There are no new unread posts for this topic. aluminum frame drilling for internal DI2
rOYk
7
792
Tue Nov 20, 2012 10:59 am
rOYk View the latest post
It is currently Thu Jun 20, 2013 1:09 am
Shimano Dura-Ace Di2 components at cheap prices - starbike.com
