Post new topic Reply to topic  [ 2 posts ]
PostPosted: Sun Jul 01, 2012 1:22 am
Just got that on my bike this morning, works perfect. I do have a question, right now the FD is set up to have 3 trim levels in the small ring, and two for the large ring, its working good, just want to make sure its right.
the set up is 50/34 by 11-23. In the big ring, I can be from 19-11 in the most outside setting, if I really need to be in the 21 or 23, then I can trim it to the inside a little bit before dropping to the 34. Please let me know if this is correct, or is there a better way to do this, Im totally happy how it is, I was just wondering=)
PostPosted: Sun Jul 01, 2012 1:41 pm
It should require 3 clicks of the finger lever to cover the full range of travel. From the big ring, one click will eliminate the chain rub when using the two largest cogs. The FD can also work OK with four clicks, but the first click of the finger lever probably does nothing but take up some cable slack.
Users browsing this forum: drainyoo, Exabot [Bot] and 50 guests
There are no new unread posts for this topic. Sram Red front derailleur(non yaw) with Chorus 10 speed shif
digiadaamore
Wed May 15, 2013 10:19 pm
dereksmalls View the latest post
There are no new unread posts for this topic. campagnolo 11 sp chorus front der HELP!
digitalnorbs
7
450
Sat Aug 25, 2012 3:09 am
There are no new unread posts for this topic. Campy chorus 10 speed creaking under load
digitalnorbs
Thu Jun 21, 2012 10:11 pm
ParisCarbon View the latest post
There are no new unread posts for this topic. Campy Chorus 11 speed group/break pads advice
digitalnorbs
10
352
Tue Jan 15, 2013 8:51 pm
bm0p700f View the latest post
There are no new unread posts for this topic. 10 speed shifter on 9 speed front only
jamr1
Fri Oct 19, 2012 9:02 am
mrfish View the latest post
It is currently Thu Jun 20, 2013 5:00 am
