Post new topic Reply to topic  [ 8 posts ]
 Post subject: Wheel upgrade
PostPosted: Fri Jun 29, 2012 6:48 am
Hi guys,lloking for some advice/thoughts on wheels.
Im running some 4za stratos http://www.4za.com/wheels/stratos/item/ ... tos-wheels which after some use are heavy and slow.
looking to upgrade to something like campag zondas http://www.campagnolo.com/jsp/en/wheels ... tid_10.jsp or american classics http://www.amclassic.com/en/products/ro ... 20road.php
buget is no more than £500,most of my rides are on lumpy british roads/hills and some bigger hills.
thanks for your advice/thoughts
 Post subject: Re: Wheel upgrade
PostPosted: Fri Jun 29, 2012 7:10 am
Yikes those are a touch heavy!
I have just got a set of Fulcrum racing 3s, basically Zondas. I got them from Wiggle quite cheaply. I then replaced the balls with ceramics, and they are the nicest rolling set of wheels I've ever ridden! I forgot to weigh them before fitting them, but you should save a good amount over the stratos.
They also have bladed steel spokes which are more aero than the higher level wheels. I'm a big rider and don't find stiffness to be an issue. I had some older model zondas and the pulling spokes on the drive side started cracking at the rim. However the new rims have the machined centre sections, so the area around the spoke holes are very thick.
Basically - I really like them!! I would like 18/24 spoking, but no actual issues (currently) with the 18/21
You will then have some cash left in the budget for some nice tires etc.
signature deleted by the Admin.
PostPosted: Fri Jun 29, 2012 7:48 am
cheers John,what diffrence does ceramics bearings make?
PostPosted: Fri Jun 29, 2012 12:09 pm
Depending who you talk to (and I sell them) they reduce rolling resistance a little. I've upgraded Dura Ace hubs and now two sets of campy hubs, and I noticed the improvement more on the campy hubs. Campy hubs roll fantastically anyway, if you are so inclined you can add a little icing on top by swapping the balls for 30x 5/32" silicon nitride balls front and rear (60 total). Very easy to replace all you need is a few allen wrenches and some nice grease.
PostPosted: Fri Jun 29, 2012 12:36 pm
campag record hubs and ambrossio f20 are my shout if the roads where you live are like where i am they easy to rebuild comftable and under budget. im pro tubular have you considerd using them in my eyes the best upgrade for a wheelset.
i cracked a zonda rear hub so wasnt happy about that and belive that custom wheels are the best option for a quickfix.
Full steam we go against the odds
Headfirst we go against the grain
Against the odds, against the grain
We go against the odds, against the grain
PostPosted: Sat Jun 30, 2012 9:05 am
Would chime with the quality of campag hub bearings, i used an aged rear scirocco for awhile and was amazed at the spin cycle. At this stage the Zonda's or record hubs with a rim that can land in the same weight region-mid 1500g's- would be my advice. It won't be open pro's as they will nudge the late 1800g's.
PostPosted: Sat Jun 30, 2012 9:17 pm
Sorry that was wrong. I was quoted at 1765g for Record on open pro. Fabulous hubs though,their on my mind.
PostPosted: Sat Jul 07, 2012 1:35 pm
cheers will let you know what i choose
Users browsing this forum: Bing [Bot], Google Adsense [Bot], Kam0916 and 37 guests
There are no new unread posts for this topic. Single speed wheel upgrade help!
daverissin
14
729
Thu May 31, 2012 4:32 pm
bm0p700f View the latest post
There are no new unread posts for this topic. Attachment(s) 3D Printed Disc Wheel Valve Cover with wheel Magnet
RaceWareDirect
Wed Sep 05, 2012 11:04 pm
cyclenutnz View the latest post
There are no new unread posts for this topic. upgrade old bike or buy new one
kamil1891
15
864
Mon Jan 07, 2013 8:45 pm
kamil1891 View the latest post
There are no new unread posts for this topic. What to upgrade this winter
russianbear
Wed Oct 10, 2012 9:24 pm
Zen Cyclery View the latest post
There are no new unread posts for this topic. What upgrade would you guys do?
markyboy
9
680
Sat Dec 15, 2012 11:22 pm
sugarkane View the latest post
It is currently Sun May 26, 2013 5:14 am
