It is currently Wed Apr 26, 2017 7:05 pm
Post new topic  Reply to topic  [ 5 posts ]
PostPosted: Thu Jun 28, 2012 9:03 pm
Hey Guys,
Ok, I have bit of a problem. I have a 2012 BMC SLR01 Di2 frame (normal seat post clamp) and the seat post won't budge a bit! It's always been tight from day one but now she is stuck solid. Any tips or ideas on how to free her up? I can't twist it as it's a propriety seat post.
Anyone else encountered this issue?
I've emailed BMC but am still awaiting reply.
Cheers in advance.
Instagram
Instagram - Work
Alluminati - CAAD10
PostPosted: Thu Jun 28, 2012 9:17 pm
If it where mine I'd be tempted to try some penetrating oil like 'plus gas' on it but I don't know how the carbon would be affected (if at all). If you can try some on a piece of carbon you don't care about that would be my suggestion.
I have had my SLR01 for just over a week now and I'm loving it!
PostPosted: Thu Jun 28, 2012 9:36 pm
Try using baby oil, veg oil etc... and a few minutes later hit it with a blow dryer to get the frame to expand. Good luck and let us know what works.
PostPosted: Thu Jun 28, 2012 9:49 pm
I don't think those oils will flow easily enough to get in such a tight gap. Worth a try though because they definitely won't damage anything.
You could take the seat post clamp off (slide it up) and try and get some down the edge that way maybe? Heat could also work but do not get the frame too hot because you can damage it.
PostPosted: Thu Jun 28, 2012 9:51 pm
FIXED
Gave the post a few downward wacks with a rubber mallet (with a saddle on it of course) and that broke the seal that was being created by the grit that had worked it's way down the post. Then pulled it out. Boom.
FYI - Grit will get down your SLR01 post if you ride in the rain, so every now and then take it out and give it a clean.
Cheers for the tips.
Instagram
Instagram - Work
Alluminati - CAAD10
There are no new unread posts for this topic. Carbon seat + post : Remove bracket/rails and attach seat directly to post - bonding?
alcatraz
Sun Oct 23, 2016 4:07 am
KarlC View the latest post
There are no new unread posts for this topic. Your Experience - Ti Seat post vs Carbon Seat Post
McGilli
13
1465
Mon Jul 18, 2016 1:30 pm
TheDarkInstall View the latest post
There are no new unread posts for this topic. Seat Post Question
KCookie
Thu Feb 09, 2017 1:36 am
KCookie View the latest post
There are no new unread posts for this topic. Attachment(s) Canyon SLX Seat Post Clamp
scruffmeister
Sun Oct 23, 2016 12:02 pm
tarmackev View the latest post
There are no new unread posts for this topic. So I snapped my seat post clamp...
McGilli
15
1156
Sun Sep 11, 2016 5:36 am
RyanH View the latest post
Users browsing this forum: Bing [Bot], chazmtb, dak, jch3n, MisterNoChain, NealH, Pokerface07, thePrince, Vermu and 36 guests
