Post new topic Reply to topic  [ 11 posts ]
PostPosted: Thu Jun 28, 2012 7:30 am
With thanks to user Roeboe http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=94146
He weighed his pedals on his new build. I find them surprisingly light (under Shimano's claim):
http://flic.kr/p/atddoY
My experience with Shimano pedals has been very good, so I expect these to be quite nice as well. Is the difference the sealings? At fist glance at the technical documents they have similar bearings.
* I must be dense, can't post the picture, only the link. :oops:
PostPosted: Fri Aug 10, 2012 9:09 pm
Sorry to bring back from the dead but I didn't want to make a new topic if I didn't have to.
Anyone know what material the spindles are on these Ultegra Carbon pedals? Cro-Mo is my guess. I checked the Shimano tech documents and it doesn't say for sure. The part number is different than the regular 6700, 105 5700 and R670 alloy pedals and different than the Dura Ace 7900 pedals.
ASSuming these are Cro-Mo, does anyone know if Ti spindles are available? I emailed tispindles.com but didn't get any answer. I see they have an option for the alloy 6700, 105 5700 and R670 pedals but since the part number is different I would assume it will not fit the carbon pedals.
If there were Ti spindles available and they saved ~60g like on the alloy pedals then the combination of the Ti spindles with the carbon pedal would be right around 200g which would be amazingly light for a Shimano pedal. The Dura Ace 7900 is only 10g less than the Ultegra Carbon but about $100 more so the Ultegra + Ti would be an amazing deal.
Any thing I missed?
PostPosted: Fri Aug 10, 2012 10:18 pm
I just bought these pedals on Chainlove - sweet deals. I currently do not know of any tuning procedure for this set of pedals, but I am very interesting in hearing about options if available.
Cervélo S2 2012 Red
Great minds think alike... sadly, so do the mediocre ones.
PostPosted: Sat Aug 11, 2012 1:47 am
All the Shimano SPD-SL pedals have steel spindles. I have not seen a Ti one for them yet.
The axles are different because the Ultegra and DA pedals use different bearings.
PostPosted: Sat Aug 11, 2012 3:20 am
... and the ultegra carbons use a different axle compared to ultegra aluminums. the carbon pedal has no wrench flats, 8mm allen to install, and a hex for the bearing assembly.
PostPosted: Sat Aug 11, 2012 1:03 pm
I wish the spindles were shorter like the Dura Ace pedals. I also wish we had an accurate measure of pedal center to crank to know wxactly how much longer these spindles compared to Dura Ace.
PostPosted: Sun Aug 12, 2012 1:18 am
I didnt do direct measurement, but i did do a "relative" measurement of axle-to-cleat-center. It was very hard to tell: either they were exactly the same, or the dura ace (carbon) was less than 1mm narrower than the ultegra (carbon).
PostPosted: Sun Aug 12, 2012 3:21 am
Really?! If that's the case I could cetainly use Ultegra carbons on my second bike my concern was more Q-factor. Thank you
PostPosted: Sun Aug 12, 2012 3:51 am
If the DA spindles are shorter, wonder if that is the entire 10 gram difference? Someone needs to start making Ti short spindles for these...
Sent from my iPad using Tapatalk HD
PostPosted: Sun Aug 12, 2012 7:32 am
On DA, there's not much room to make them shorter. In fact, for the 9000 version, they will offer a longer spindle version as an option (4mm longer spindle). If i was interested in getting my foot closer to the crank arms (im not, im going the other way), i would work on the sh11 cleats instead. The plates, and the very large heads on the screws, really limit positional adjustment. Some plate hacking, some different screws, go a long way.
PostPosted: Sun Aug 12, 2012 1:42 pm
Same here, I did a comparison between the 2, I couldn't tell the difference between the thread lip and the approximate cleat center of the 2 pedals. Visually, they seem the same. Though the Ultegra seems wider if the look at them as complete pedals rather than their cleat center measurements. :noidea:
Users browsing this forum: climberevan, Google Adsense [Bot], jdott, kulivontot, Ritterview, Shinobi and 51 guests
There are no new unread posts for this topic. 2012 Rose carbon pro RS Ultegra DI2
WasFab
Sun Jun 24, 2012 3:50 pm
WasFab View the latest post
There are no new unread posts for this topic. Dura Ace 7900 vs. Ultegra 6700c Carbon?
ScottGoBlue
Thu Nov 22, 2012 4:46 pm
maxxevv View the latest post
There are no new unread posts for this topic. Shimano Ultegra 12-30 Cassette With Ultegra Di2?
SpeshK
Tue Feb 05, 2013 5:13 pm
SpeshK View the latest post
There are no new unread posts for this topic. Can carbon frames be too light?
steel515
29
2401
Wed Jan 09, 2013 3:27 am
There are no new unread posts for this topic. Attachment(s) Light Intergrated carbon bar stem?
CBRE
11
954
Fri Nov 02, 2012 9:49 pm
Mattias Hellöre View the latest post
It is currently Sat May 25, 2013 5:43 am
