Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 122 posts ]
Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
PostPosted: Sat Jul 07, 2012 7:18 am
kai-ming wrote:
..... In fact, I have done drilling holes at the upper bridge of a Ambrosio exellight rim of a front wheel for years without any problem at all. However, the wall thickness of the upper bridge is not thick so the weight saving there is little.
As I have said earlier that I have done the same thing that thisisatest did, three holes per space between spokes on the front wheel. It hold up well, I have used it for my everyday training for years. I was also disappointed on the weight saving, so I did not bother to drill on the rear rim.
PostPosted: Sat Jul 07, 2012 9:41 am
How big were the holes you drilled?
My view on this is that a 32spoke MTB wheel is FAR more robust than a 20 spoke R500 front wheel.
Sounds like the wheel must have been fairly "soft" to begin with, and the drilling didn't take out much.
Here is a thought actually. Say the R500 rims weigh 500grams (heavy rims medium profile) and you remove maybe 5% of the material(?)
You are going to save 25grams a wheel.
Even 10% off the rim and you save 50grams per wheel
Still going to be heavy wheels, and more likely to fail....
signature deleted by the Admin.
PostPosted: Sat Jul 07, 2012 7:49 pm
to the op.. go do it. i mean this IS ww............ duh
Mass Weenie
PostPosted: Sun Jul 08, 2012 12:39 am
The amount of effort and time it's going to take you drill up your heavy aluminum wheels... you could probably spend that time doing some jumping-jacks and drop a pound off your belly, compared to a few grams off your heavy rims. Just saying.
PostPosted: Sun Jul 08, 2012 3:47 am
Or working to earn money for a real set of wheels that won't kill you.
PostPosted: Sun Jul 08, 2012 3:54 am
Do both.
Exp001
PostPosted: Sun Jul 08, 2012 12:20 pm
prendrefeu wrote:
Do both.
:thumbup: Real weight weenies.
PostPosted: Sun Jul 08, 2012 6:33 pm
kai-ming wrote:
I have asked these simply strict questions in my previous posts.
1. Correct me if I am wrong. Yes, rim is designed to have hole cut in between spoke holes, i.e. hole for the tube valve. I have not heard of failure at the lower bridge of the rim between spoke holes or certainly not at the hole for the tube valve which is located in the middle between spoke holes. So, at least it would be safe to drill holes of the same diameter at the lower bridge in between spokes holes ?
2. Please explain to me why you wouldn't worry about the valve holes which go through both bridges of the rim ? I suppose the thickness of lower bridge has been designed to have the strength to take the force of spoke, therefore it could be considerably overbuilt in between spokes. Proof me wrong if you have better answer i.e. testing/calculations/computer modelling that you have heard of on this subject.
Simple.
Shimano, or whoever design the product in question, have designed their rim with the spoking pattern in mind from the outset. They will have used a dedicated machine to form the holes for the spokes and valve in such a way that it does not cause stress risers. Additionally, shimano may have, as one poster suggested, used heat or surface hardening treatments. This may very well have been done after the holes were made. Your drilling into the treated metal could have adverse effects that will render the original treatment ineffective.
But as another poster observed, Darwin Awards are still awarded.
PostPosted: Tue Jul 10, 2012 4:00 am
this is an r500 wheel. i seriously doubt any surface treatment was done. heat treatment-doubly doubt. drilling w/o causing stress risers- use a very sharp bit, cooling oil... this isnt their topoftheline super-duper rim, this is the cheapest one they make. is it even welded at the seam? what would the heat treatment be for, anyway? as i said before, there are so many much, much stupider things done every day by members of this very forum, i dont see why everyone's getting so critical with this one. it's not like he's drilling holes in his TIRES or INNER TUBES.
PostPosted: Tue Jul 10, 2012 4:12 am
drilling tires or tubes that might actually be safer...
PostPosted: Tue Jul 10, 2012 4:42 am
thisisatest wrote:
this is an r500 wheel.... as i said before, there are so many much, much stupider things done every day by members of this very forum, i dont see why everyone's getting so critical with this one.
Yeah, seriously. It's like WW has a forum full of non-weight weenies all of a sudden. WTF are you all doing here if you aren't interested in tuning and getting the most out of your components as the very basis of the forum? The CycleChat and Pro talk and all the other stuff is just icing on the cake.
Besides, donald, who has the lightest bike on the forum and has tuned everything from low-end components to high-end ones, has personally tuned/drilled and modified MAGNESIUM clincher rims from a non-major manufacturer that doesn't even exist anymore (well, maybe the guy is alive, but the rims are not produced anymore). He rides them every single day for countless miles... No catastrophic failures to make people on the internet have their inflated fears verified.
...and people here are whinging over someone doing calculated drills on a heavy-ass low-end Shimano rim? :noidea:
People say its easier to lose weight elsewhere - no sh*t. Why not do both?
People say its easier to make a lot of money to pay for higher end components... yes, but so what? Why should that stop anyone from modifying components on their free time, high end or not? Besides, WW is NOT about buying the lightest and most boutique out there, although some people especially recently have taken that route instead of using their heads to figure things out, taking the effort to modify and tune components, and building up the bikes themselves.
Exp001
PostPosted: Tue Jul 10, 2012 5:16 am
One can be a WW, but it doesn't have to be in every bike component nor at the expense of anything whether it be cash, ride quality, etc.
When it potentially involves safety, then no amount of weight is worth risking your life for. Whether those concerns are founded, I don't know. Just intuitively to a lot of people, it seems that drilling holes in a wheel is going to weaken the rim and cause it to fail. I can see why people would get worked up about it- if this really is an unsafe project and the rim fails during a group ride because of that, other lives are also put at risk.
Personally, I just see these kinds of wheels serve their purpose as training wheels where weight isn't really a concern- as they say, you can't polish a turd. I believe people are overblowing the safety issue as these wheels are way overbuilt.
Flickr
2012 Cannondale CAAD10
PostPosted: Fri Jul 20, 2012 2:23 pm
So, how'd it go?
"Nothing compares to the simple pleasures of a bike ride," said John F. Kennedy, a man who had the pleasure of Marilyn Monroe.
PostPosted: Sat Jul 21, 2012 12:01 am
Dead? Hospital? Dentist?
PostPosted: Sat Jul 21, 2012 1:40 am
Online
Just spend $300 and build a niobium clincher already. This is a really pointless discussion. All this effort to get to 1600 grams is pointless when lighter wheelsets are a dime a dozen.
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 122 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
Users browsing this forum: Google [Bot], Google Adsense [Bot], kulivontot, locktopus, sjg14, Vuong05 and 35 guests
There are no new unread posts for this topic. Shimano Powertap wheel idea
PoorCyclist
10
752
Thu Jun 14, 2012 10:29 pm
PoorCyclist View the latest post
There are no new unread posts for this topic. Shimano jockey wheel compatibility
liam7020
Wed Jan 09, 2013 6:17 pm
bura View the latest post
There are no new unread posts for this topic. Shimano 10s to Campy 11s rear wheel...re-dish needed or not?
Voye
Wed Feb 20, 2013 10:43 pm
boolinwall View the latest post
There are no new unread posts for this topic. Enigma Elite Steel frame - material choice
leguy
22
1152
Tue Aug 28, 2012 9:06 am
ticou View the latest post
There are no new unread posts for this topic. Excess material inside carbon fibre top tube of SuperSix
gabriel959
Thu Jun 21, 2012 8:32 pm
gabriel959 View the latest post
It is currently Sun May 19, 2013 2:19 am
