Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 122 posts ]
Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Sat Jun 30, 2012 8:56 am
We are talking about stiffness to resist stress aka resist plastic deformation. You're just asking for your wheels to taco and fold. There has never been a design of road bike wheels in production with holes drilled in between every spoke (and that's even considering they use that as a design feature, not some amateur who wants to modify the initial design). Think about that. You're going to weaken the rim until it will flex like a piece of paper. The rim Aluminum thickness is far too thin to be cutting holes everywhere. Typical load bearing structures that have holes cut in them to save weight are far beefier than a wheel rim and are considerably overbuilt with supporting trusses. There's tuning aesthetic non load dependent pieces and then there's tuning significant load dependent functional parts. This is the latter. And yes, you will likely endanger your life if you do this.
I am an mechanical engineer by trade. This is an INSANE thing to do. Don't do it unless you are prepared to die. I'm not even joking.
PostPosted: Sat Jun 30, 2012 9:03 am
Here is a legitimate idea. Sell your R-500's and buy a lighter set of wheels. That way you will save on grams and dentistry bills.
PostPosted: Sat Jun 30, 2012 9:52 am
Hi there, I am an qualified mechanical engineer too i.e. Chartered Engineer. Please explain to me why you wouldn't worry about the valve holes which go through both bridges of the rim, while you worry other hole on the lower bridge only. I understand cutting holes will weaken the rim to an extend, but all these talk about explosion of the wheel is just exaggeration. I have not heard of tests on the strength of rim at the valve hole. Enve worry about the strength at spoke holes, so they do test on that http://www.bikeradar.com/gallery/articl ... 96/?img=31" onclick="window.open(this.href);return false;
I suppose the thickness of lower bridge has been designed to have the strength to take the force of spoke, therefore it could be considerably overbuilt in between spokes. Proof me wrong if you have better answer i.e. testing/calculations/computer modelling that you have heard of on this subject.
PostPosted: Sat Jun 30, 2012 10:05 am
I probably have not explain myself clearly. The R500 was brought with the intention to experimenting on tuning of a heavy cheap rim, so that has to be a heavy rim. I don't think there will be anything bad happen to my teeth.
PostPosted: Sat Jun 30, 2012 10:23 am
As a matter of fact, Mavic think their rim is considerably overbuilt in between spokes, so they do ISM3D to their rim.:smartass: http://roadcycling.mavic.com/en/technol ... hno__ism3d
PostPosted: Sat Jun 30, 2012 11:21 am
In fact trials riders use rims with massive holes drilled all the way thru in between the spokes, and those are fairly plain rims with no extra features or reinforcements to make that possible, they're just plain simple drilled holes. And well, if a trials rider don't taco their rims - and believe me they both punish their rims AND put down a serious pedal kick for acceleration... well then I just don't see a roadbike rider doing it either.
In the early 90's it was, well maybe not common but atleast not unusual, to drill your own MTB rims in between spokes the DIY way, and they held up just fine.
But I think weight wise you might do better with shaving (á la Mavic) than drilling, if you can just find a way to tell exactly how much you're shaving off. I remember someone did the math on that on another forum a couple years back, and shaving actually takes away more material than drilling would (when all things done within reason). Still tough, we are talking savings in the 15-25 grams range per rim, at best.
Roadbike
Kinesis RaceLight T2
Mountainbike
Van Nicholas Zion Ti
PostPosted: Sat Jun 30, 2012 12:37 pm
Hyperbole aside there are some simple structural principles to consider. Side to side (lateral) stiffness depends mainly on the sidewalls. The spoke bed and rim bed are not highly stressed in this loading mode. However loading in the vertical plane is resisted most by the material at the extreme top and bottom of the rim section i.e. at the bead hooks/brake tracks and the spoke bed. Putting a row of holes through the spoke bed will certainly compromise the vertical stiffness and strength to some degree. How much I couldn't say.
As far as vertical compliance is concerned, so called 'soft riding' rims actually don't flex very much and probably not significantly. In other words the soft ride is much more a function of tyre pressure and seat stay/seat post/seat flex. If a rim flexes significantly spoke tension fluctuates significantly through the load cycle. If it's too much it leads to spoke fatigue failure. Also the rim itself is setup for early fatigue failure so a flexible rim is not a good thing generally.
If you were to drill a line of holes through the spoke bed between the spokes there is a very real danger of cracks initiating at the drilled holes and going up the side walls. And just because the rim survives for some months/years does not mean it wont happen. The longer the rim is ridden the closer it comes to failure.
That said heavy rims are heavy partly because its cheaper to build them that way and partly for reliability for heavy riders, so they are somewhat stiffer/stronger than they need to be. With that and your light weight in mind I think it would be safe to drill the holes. If you do you should take care to leave ample web between the holes, don't drill near the spokes and make the holes smooth to avoid stress risers.
I googled for drillium and found only 1 reference to drilling rims. That was a fat tyre mtb rim with heaps to spare. Even so I think its obvious that the author has forgone a lot of rim life. If you look at the distribution of material around the spoke heads you can imagine that with a bit of cyclic spoke tension the web between the holes will fail. Many of the examples of drillium you will find on the web are stupidly fragile. Its a pity they dont post the failure photos.
http://fat-bike.com/2011/11/tech-drilling-fat-rims/" onclick="window.open(this.href);return false;
In summary I wouldn't do it myself because there is little to gain and potential for dangerous failure. Regular inspection should reveal incipient cracks, but then again it could happen very quickly. I'd sell them as they are and build some light weight clinchers if I were you. That way you learn some handy skills and acquire some cheap light wheels. You can build a set at ~1300g for about $300 materials cost not including tools.
r o y g b i v
PostPosted: Sun Jul 01, 2012 2:32 am
Alright, SIT TIGHT! :mrgreen:
PostPosted: Sun Jul 01, 2012 4:02 am
you could start small to start with if you really want to do this....
signature deleted by the Admin.
PostPosted: Sun Jul 01, 2012 5:09 am
Do it, drill that sucker. Do it for the lulz
PostPosted: Sun Jul 01, 2012 5:18 am
I can tell by the super accurate cutting line that a lot of technical thought has been put into this.
+1. Lulz will be had.
PostPosted: Sun Jul 01, 2012 11:16 am
And make sure you have someone take a video of you on your first ride with them :thumbup:
PostPosted: Sun Jul 01, 2012 11:49 am
:thumbup: :beerchug: :popcorn: :faint:
PostPosted: Sun Jul 01, 2012 12:52 pm
Appears like it's going to be a nice neat professional looking job...
PostPosted: Mon Jul 02, 2012 10:31 am
Why even ask the question when you intend to do it anyway and dismiss every answer that explains why it's a bad idea? Baffling.
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 122 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
Users browsing this forum: Google [Bot], lechat and 53 guests
There are no new unread posts for this topic. Shimano Powertap wheel idea
PoorCyclist
10
759
Thu Jun 14, 2012 10:29 pm
PoorCyclist View the latest post
There are no new unread posts for this topic. Shimano jockey wheel compatibility
liam7020
Wed Jan 09, 2013 6:17 pm
bura View the latest post
There are no new unread posts for this topic. Shimano 10s to Campy 11s rear wheel...re-dish needed or not?
Voye
Wed Feb 20, 2013 10:43 pm
boolinwall View the latest post
There are no new unread posts for this topic. Enigma Elite Steel frame - material choice
leguy
22
1168
Tue Aug 28, 2012 9:06 am
ticou View the latest post
There are no new unread posts for this topic. Excess material inside carbon fibre top tube of SuperSix
gabriel959
Thu Jun 21, 2012 8:32 pm
gabriel959 View the latest post
It is currently Thu May 23, 2013 1:34 am
